What's Wrong Here? Hint: Rest in Peace
What is in this article?:
How well do you know the Code? Think you can spot violations the original installer either ignored or couldn’t identify? Here’s your chance to moonlight as an electrical inspector and second-guess someone else’s work from the safety of your living room or office. Can you identify the Code violation(s) in this photo?
Hint: Rest in peace
Discuss this Article 2
Mr Dee's Electric LLC (not verified)
on Jun 24, 2012
The weatherproof box is damaged, the connection from pvc pipe to (Romex) is not connected properly. The receptacle has to be Gfci protected the cover also needs to flip around so rain can go around it. And finaly the connection from weatherproof box to pvc is damaged and will not protect the device from the outdoors elements
Dave Radford (not verified)
on Dec 6, 2012
Looks pretty old, I would guess that there is a GFI somewhere up the line to protect the receptacle. Also the conduit, not even sure if there is wire still connected. I will not assume that there is, I imagine that it was something demoed, cut off at ground level and left to rot.
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
