What's Wrong Here? Hint: Mix and Match
What is in this article?:
This photo shows threaded rigid metal conduit (RMC) that was installed in a wet location (i.e., on a roof). As you can see, these two pieces of conduit were joined together with a compression coupling.
While the compression coupling itself might be listed for use in a wet location, when installed on the threaded end of the RMC it is probably not very watertight. This would be a Code violation unless the connector was specifically listed for this purpose.
Section 344.42(A) requires threadless couplings and connectors to be made tight when used with conduit. Where buried in masonry or concrete, they shall be the concrete-tight type. Where installed in wet locations, they shall comply with the requirements of 314.15. Threadless couplings and connectors shall not be used on threaded conduit ends unless listed for the purpose.
> Try Another Quiz
Discuss this Article 8
Jose A. Guillen (not verified)
on Jun 21, 2012
The connector is missing the plastic bushing to make it water tight.
jbaum2002 (not verified)
on Jun 22, 2012
emt compression connector on threaded rigid conduit
Mr. M (not verified)
on Jun 22, 2012
EMT rain-tight coupling improperly used to join RSC.
on Jun 22, 2012
You cannot use a emt rt coupling to join a length of ridged conduit..
Dave Reichman (not verified)
on Jun 22, 2012
Connector not listed for use on ridgid conduit. Listed for EMT as a rain tite compression connector.
mike fisher (not verified)
on Jun 23, 2012
It looks to me like they used a ridgid thredless connector in the wrong place, on threads at least one side,wrong application.
rogerober
on Jun 25, 2012
Connector not installed according to its listing
Anonymous (not verified)
on Jun 25, 2012
you cannot use a threadless coupling on a thread
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
Protection From Arc Flashes
Learn how arc flashes happen, how they are measured and how wearing the right flame resistant clothing can keep workers safe....More
Newsletter Signup
Connect With Us
