What's Wrong Here? Hint: I Have Some Shocking News to Share
What is in this article?:
In accordance with 250.94, an intersystem bonding termination for connecting a minimum of three intersystem bonding conductors required for other systems shall be provided external to enclosures at the service equipment or metering equipment enclosure.
Exception: In existing buildings, if any of the intersystem bonding and grounding electrode conductors required by 800.100(B)(2) exist, installation of the intersystem bonding termination is not required. An accessible means external to enclosures for connecting intersystem bonding and grounding electrode conductors shall be permitted at the service equipment by at least one of the following means:
1) Exposed nonflexible metallic raceways
2) An exposed grounding electrode conductor
3) Approved means for the external connection of a copper or other corrosion-resistant bonding or grounding electrode conductor to the grounded raceway or equipment
As noted in 800.100(B)(2), "A bonding device intended to provide a termination point for the grounding electrode conductor (intersystem bonding) shall not interfere with the opening of an equipment enclosure. A bonding device shall be mounted on non-removable parts. A bonding device shall not be mounted on a door or cover even if the door or cover is non-removable."
The telephone system bonding/grounding wire attached to the cover screw at the top of the meter enclosure definitely interferes with the opening of the cover. The phone system would lose its ground/bond connection every time the meter enclosure cover needed to be removed for maintenance or servicing of the electrical system. This could result in a difference of potential between the two systems and could result in a shock or fire hazard.
> Try Another Quiz
Discuss this Article 5
Francisco Cruz (not verified)
on Jul 5, 2012
Only thing i can see wrong , the G.E.C. from Phone Board Equipment needs to be properly connected to the grounding bar inside the meter equipment .
Can't see clearly if anything in front of meter equipment .
Anonymous (not verified)
on Jul 6, 2012
Telephone closets an electrical closets should be separate , unless there is special permission?!
Bob O'Brien (not verified)
on Jul 6, 2012
1. Ground conductor to telephone equiment is not connected to the system ground, the cover screw is not to be used as a ground terminal and would disconnect the ground if the cover was to be removed for service.
2. The grounding conductor should be fastened to the structure. As is it could easily be accidentally disconnected or broken
Phill.Guillory
on Jul 6, 2012
According to the National Electric Code, the telephone service, cable TV, satellite, and other antenna grounds must be connected to the same ground point of the incoming electrical service to provide proper protection.
Also, the faulty grounding electrode conductor is run (twice) across a 25 pr. station cable.
Russ LeBlanc (not verified)
on Jul 28, 2012
Thank you all for commenting!
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
Protection From Arc Flashes
Learn how arc flashes happen, how they are measured and how wearing the right flame resistant clothing can keep workers safe....More
Newsletter Signup
Connect With Us
