What's Wrong Here? Hint: I Have Some Shocking News to Share
Discuss this Article 5
Francisco Cruz (not verified)
on Jul 5, 2012
Only thing i can see wrong , the G.E.C. from Phone Board Equipment needs to be properly connected to the grounding bar inside the meter equipment .
Can't see clearly if anything in front of meter equipment .
Anonymous (not verified)
on Jul 6, 2012
Telephone closets an electrical closets should be separate , unless there is special permission?!
Bob O'Brien (not verified)
on Jul 6, 2012
1. Ground conductor to telephone equiment is not connected to the system ground, the cover screw is not to be used as a ground terminal and would disconnect the ground if the cover was to be removed for service.
2. The grounding conductor should be fastened to the structure. As is it could easily be accidentally disconnected or broken
Phill.Guillory
on Jul 6, 2012
According to the National Electric Code, the telephone service, cable TV, satellite, and other antenna grounds must be connected to the same ground point of the incoming electrical service to provide proper protection.
Also, the faulty grounding electrode conductor is run (twice) across a 25 pr. station cable.
Russ LeBlanc (not verified)
on Jul 28, 2012
Thank you all for commenting!
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington Cable Entrance Plates
Arlington’s new REVERSIBLE entrance plate not only protects cable but delivers good looks and installation versatility. Use it facing in or out. Non-rusting paintable plastic....More
Newsletter Signup
Connect With Us
