What's Wrong Here? Hint: Disappearing Act
Discuss this Article 5
Samuel Silva (not verified)
on Jun 7, 2012
The wood brace doesn't look as if it is treated lumber any outdoor outlet is subject to weather. Therefore, Code 314.23(B)(2) is being violated. Plus, the clamp connected to the wood isn't protected against corrosion and deterioration as prescribed in article 300.6.
Anonymous (not verified)
on Jun 7, 2012
You're on utility ground in the photo and utilities follow the NESC, not the NEC.
Russ LeBlanc (not verified)
on Jun 11, 2012
The poles are the customer's lighting poles for a mini-golf and driving range! This is covered by the NEC
on Jul 6, 2012
The clamp is not listed for the environmental condition(sunlight most probably) and the rapid oxidation and disintegration is progressing to the point that the clamp no longer provides the required performance.
Dave Radford (not verified)
on Dec 6, 2012
That looks like an old asbestos clamp. I was made with a blend of plastic and asbestos. Over time it would dry out and start to crack, break and become brittle. I do not see any code violation here. It would only become a code violation is a company did some work on the pole and did not update the strapping.
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington TV Box for New Construction
Arlington’s recessed combination power and low voltage boxes – TV BOX™ and Indoor IN BOX™ – offer secure, convenient & easy way to mount LCD or plasma TVs flush against a wall...More
Newsletter Signup
Connect With Us
