January Winners
Our three winners this month (Michael J. Lewis, P.E., director of engineering field services, Fidelity Real Estate Company, LLC, Durham, N.C.; Thomas B. Carron, P.E., senior engineer, Integrated Design Solutions, Architecture, Engineering, Interiors & Technology, Troy, Mich.; and Brian Burke, P.E., senior electrical engineer, High Voltage Maintenance Corp., Middletown, Ohio) all correctly identified the following Code violations associated with the January 2008 photograph.
As per 406.9(B) [Grounding-Pole Identification], “Grounding-type receptacles, adapters, cord connections, and attachment plugs shall have a means for connection of an equipment-grounding conductor to the grounding pole. A terminal for connection to the grounding pole shall be designated by one of the following:”
Of the four options in this section, let's focus on item (3), which states, “A similar green-colored connection device, in the case of adapters. The grounding terminal of a grounding adapter shall be a green-colored rigid ear, lug, or similar device. The equipment grounding connection shall be so designed that it cannot make contact with current-carrying parts of the receptacle, adapter, or attachment plug. The adapter shall be polarized.”
In addition, the winners also cited 200.11 [Polarity of Connections], which states, “No grounded conductor shall be attached to any terminal or lead so as to reverse the designated polarity.”
Correctly identify the Code violation(s) in this month's photo — in 200 words or less — and you could win something to put in your toolbox. E-mail your response to Joe Tedesco at, and he'll select three winners (excluding manufacturers and prior winners) at random from the correct submissions. Winners will receive a set of insulated hand tools from Ideal Industries, Inc., valued at more than $125.* The set includes 9.25-inch insulated side-cutting pliers, 10-inch insulated tongue-and-groove pliers, and a 0.25-inch × 6-inch insulated screwdriver.
* Please allow six to eight weeks for delivery of tools.
