What’s Wrong Here? Hint: Failed Connection
What is in this article?:
How well do you know the Code? Think you can spot violations the original installer either ignored or couldn’t identify? Here’s your chance to moonlight as an electrical inspector and second-guess someone else’s work from the safety of your living room or office. Can you identify the Code violation(s) in this photo?
Hint: Failed connection
Discuss this Article 4
Anonymous (not verified)
on Jul 20, 2012
the strap used is not approved for grounding / wire used looks white
on Aug 9, 2012
The conduit the (ground?) is strapped to is PVC. Strap is not designed for grounding purposes.
Jim G (not verified)
on Aug 10, 2012
1. wrong grounding point
2. improper termination
3. wire not properly identified
4. if this is a total pvc water pipe system, this does not have to be grounded
on Jan 3, 2013
I don't think anyone was trying to ground the PVC pipe so much as grounding an electrical system to it!
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
