Ecmweb Com Sites Ecmweb com Files Uploads 2016 03 6 15 16 Ww Hweb
What’s Wrong Here? Hint: A Double Whammy
June 16, 2016
Hint: A double whammy
Not only is this storage cabinet blocking ready access to this panelboard and its circuit breakers, but flammable liquids are also being stored in this room as well. This is a really dangerous combination of problems. The working space for the panelboard is not permitted to be used as storage space for anything, especially flammable liquids!
Section 110.26(B) states very clearly that this working space area cannot be used for storage. Unfortunately, this is an all-too-common violation. Section 240.24(A) requires overcurrent devices (such as circuit breakers) to be located so as to be readily accessible. The definition of “readily accessible” from Art. 100 means capable of being reached quickly for operation or inspections without the need for using tools or to remove obstacles, or resorting to using portable ladders and so forth. I would say that this storage cabinet violates the intent of being readily accessible. If nothing else, it certainly elevates the danger by having flammable liquids being stored near equipment that may produce arcs or sparks, which also violates Sec. 240.24(D).
