How well do you know the Code? Think you can spot violations the original installer either ignored or couldn’t identify? Here’s your chance to moonlight as an electrical inspector and second-guess someone else’s work from the safety of your living room or office. Can you identify the Code violation(s) in this photo? Note: Submitted comments must include specific references from the 2014 NEC.
Hint: Get that monkey off your back
Tell Them What They Have Won...
Using the 2011 NEC, correctly identify the Code violation(s) in this month’s photo — in 200 words or less — and you could win a $50 gift check. E-mail your response, including your name and mailing address, to [email protected], and Russ will select three winners (excluding manufacturers and prior winners) at random from the correct submissions. Note that submissions without an address will not be eligible to win.
October Winners
Section 240.24(A) requires overcurrent devices to be readily accessible and 240.24(E) prohibits these overcurrent devices from being located in dwelling unit bathrooms. Similarly, 230.70(A)(1) requires service disconnects to be readily accessible, and 230.70(A)(2) prohibits the service disconnecting means from being located in bathrooms for any type of occupancy. The presence of the sink and tub make this area a “bathroom” as defined in Art. 100. The bathtub placement also effectively eliminates the equipment’s clear working space required in 110.26(A)(1), (A)(2), and (A)(3). The minimum safe working space required in front of this panel should be 3 ft deep and 30 in. wide. This work space should also be clear and extend from the floor to a height of at least 6½ ft.
