• Subscribe
  • About Us
  • Magazine Issues
  • Newsletters
  • Advertise
  • Shop
Skip to Navigation Skip to Content
Electrical Construction & Maintenance (EC&M) Magazine
Register Log In
  • Forgot Your Password?
close
  • NEC
    • Code Basics
    • Q&A
    • Quizzes
    • Violations
    • What's Wrong Here?
  • Design
    • Computers & Software
    • Green Building
    • Lighting & Control
  • Ops & Maintenance
    • Energy Efficiency
    • Metering & Monitoring
    • Motors
    • Test & Measurement
  • Contractor
    • Business Management
    • Estimating
    • Low Voltage & Communications
    • Project Spotlight
  • Safety
    • Arc Flash
    • Fire & Security
    • Shock & Electrocution
  • Power Quality
    • Monitoring & Measurement
    • Sags & Swells & Interruptions
  • Training
    • Workplace Learning Center
    • Events
    • Webcasts
  • Basics
    • Bonding & Grounding
  • Products
    • Product of the Day
    • Product of the Year
Advertisement
Home > NEC > What's Wrong Here? > What’s Wrong Here? Hint: Loose Screws
Oct. 4, 2012 Russ LeBlanc | Electrical Construction and Maintenance
    • EMAIL
  • Tweet
Comments 7
What is in this article?:
  • What’s Wrong Here? Hint: Loose Screws
  • Find the Answer
Advertisement
  • Prev
  • 1
  • 2
  • Print
  • reprints
  • Favorite
    • EMAIL
  • Tweet
Discuss this Article 7
Anonymous (not verified)
on Oct 4, 2012
Improper Ground
  • reply
on Oct 4, 2012
Looks like someone was welding a piece on a grounded welding table with receptacles and didn't hook up the ground from the welder. Not that that every happened here of course...
  • reply
Dan (not verified)
on Oct 4, 2012
Installer did not tighten set screws on coupling,but, there must be some type of current flowing n the E.MT., either fault current induced current or someone decided to use the E.MT. as a neutral.
  • reply
on Oct 4, 2012
Forget the loose screws, it's obvious that this conduit is being used as a current carrying conductor.
  • reply
siddig (not verified)
on Oct 5, 2012
when there is screw loose heat will occur then the joint will damage
  • reply
on Oct 8, 2012
Seen this before. A 240 volt cooler had a 120 defrost timer. No neutral, but a good conduit for ground
  • reply
Dave Reichman (not verified)
on Oct 9, 2012
The conductivity of die cast zinc connectors is about as poor as the conductivity of the steel EMT-about 10-25% of what a copper wire has. Looks like a great arguement for always running a green ground wire inside every conduit instead of relying on the EMT. I spent 13 years maintaining a 237 unit high rise apartment building and found many, many pulled apart EMT connections in the various shafts running up through the building. Service people would step on the conduits while repairing plumbing, etc. in the risers and that would leave kitchen receptacles un grounded as well as others in the units. Maybe its time to revise this short cut wiring method that works but leaves room for problems to occur over the life of a building. A lot of these problems with EMT could be prevented by not allowing conduit to be routed across a riser as the shortest route to an end point. All EMT should be close to a wall, etc. Maybe the 1951 code allowed this and it never happens today but.............
  • reply
Post new comment
(optional)
Sponsored Links
Related Articles
  • What’s Wrong Here? Hint: If Two Is Company, and Three’s a Crowd — What’s 10? 2
  • What’s Wrong Here? Hint: It's What You Don't See 10
  • What's Wrong Here? Hint: It’s Getting a Little Warm in Here 2
  • What’s Wrong Here? Hint: Crank Up the Volume 3
  • What’s Wrong Here? Hint: Too Close for Comfort 11
Sponsored by
EC&M Learning Center
2011 Electrician Exam Preparation Book & Journeyman Simulated Exam
Printed in full color, the 2011Exam Prep book covers Theory, Code, and Calculations in great detail. Clear colorful graphics...
2011 Understanding NEC Requirement for Solar Photovoltaic Systems
Solar power is new to most in the electrical industry and this expanding and exciting industry has created many NEC...
Photovoltaics for Commerical and Utilities Power Generation
This book provides an in-depth review of the solar industry development, and present-day state of the art, emphasizing...
BROWSE ALL TITLES
Advertisement
Webinars
ON DEMAND: All You Ever Wanted to Know About GFCIs & AFCIs
Abstract:  In this webinar, Mike will not only explain the current NEC requirements for GFCIs and AFCIs, but he'll explain how they operate, what causes their premature failure, and when they won't provide the safety protection you might have thought they would.
Sponsored by:
ON DEMAND: Workplace Electrical Safety: Prevention before Protection
Abstract: This webinar will teach attendees the difference between risk and hazard, and how the choice of system grounding has a direct impact on reliability and safety.
Sponsored by:
MORE WEBINARS
Advertisement
Jan. 27, 2010
video
Arlington Cable Entrance Plates
Arlington’s new REVERSIBLE entrance plate not only protects cable but delivers good looks and installation versatility. Use it facing in or out. Non-rusting paintable plastic....More
Showing 14-14 of 21 items
  • prev
  • 1
  • 13
  • 14
  • 15
  • 21
  • next
BROWSE ALL VIDEOS
equipmentone.com
Search 2.5+ million listings
prev next
Newsletter Signup
Sign-up to receive our free newsletters
Subscribe
Connect With Us
  • Twitter
  • Facebook
  • Linked In
  • RSS
Advertisement
Ecmweb.com
  • NEC
  • Design
  • Ops & Maintenance
  • Contractor
  • Safety
  • Power Quality
  • Training
  • Basics
  • Products
Site Features
  • Author Guidelines
  • RSS
  • Sitemap
  • Site Archive
  • Subscribe
  • View Mobile Site
EC&M Corporate
  • Privacy Statement
  • Terms of Use
  • About Us
  • Advertise
  • Contact Us
Follow Us
  • Twitter
  • Facebook
  • Linked In
  • RSS
Search ecmweb.com
Subscribe to the print magazine
PISCES
Related EC&M Sites
  • Electrical Wholesaling
  • Electrical Marketing
  • Transmission & Distribution World
Copyright © 2013 Penton
Sponsored Introduction Continue on to (or wait seconds) ×
