What’s Wrong Here? Hint: Loose Screws
What is in this article?:
Hint: Someone's got a few screws loose
Discuss this Article 7
Anonymous (not verified)
on Oct 4, 2012
Improper Ground
on Oct 4, 2012
Looks like someone was welding a piece on a grounded welding table with receptacles and didn't hook up the ground from the welder. Not that that every happened here of course...
Dan (not verified)
on Oct 4, 2012
Installer did not tighten set screws on coupling,but, there must be some type of current flowing n the E.MT., either fault current induced current or someone decided to use the E.MT. as a neutral.
on Oct 4, 2012
Forget the loose screws, it's obvious that this conduit is being used as a current carrying conductor.
siddig (not verified)
on Oct 5, 2012
when there is screw loose heat will occur then the joint will damage
on Oct 8, 2012
Seen this before. A 240 volt cooler had a 120 defrost timer. No neutral, but a good conduit for ground
Dave Reichman (not verified)
on Oct 9, 2012
The conductivity of die cast zinc connectors is about as poor as the conductivity of the steel EMT-about 10-25% of what a copper wire has. Looks like a great arguement for always running a green ground wire inside every conduit instead of relying on the EMT. I spent 13 years maintaining a 237 unit high rise apartment building and found many, many pulled apart EMT connections in the various shafts running up through the building. Service people would step on the conduits while repairing plumbing, etc. in the risers and that would leave kitchen receptacles un grounded as well as others in the units. Maybe its time to revise this short cut wiring method that works but leaves room for problems to occur over the life of a building. A lot of these problems with EMT could be prevented by not allowing conduit to be routed across a riser as the shortest route to an end point. All EMT should be close to a wall, etc. Maybe the 1951 code allowed this and it never happens today but.............
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
Newsletter Signup
Connect With Us
