What’s Wrong Here? Hint: It's What You Don't See
Discuss this Article 10
mike fisher (not verified)
on Sep 6, 2012
no j-box for connection, and no connector on the wire
Anonymous (not verified)
on Sep 6, 2012
No Back Box, No cover and improper grounding at ground screw
Donald Stebbins (not verified)
on Sep 6, 2012
there is no box to support fixture
on Sep 6, 2012
I do not see any box. Probably there is a romex to knob & tube wire junction somewhere behind that.
on Sep 7, 2012
Well, I know that they want to make sure there are no gaps around the perimiter of the ceiling box outer shell, but that's a little overkill, not even seeing the box - oris there even a box underneath it?
or maybe one of those overzealous drywallers got a little over excited about that popcorn spary finish :)
on Sep 7, 2012
no box, no connector.... guess someone thought they were optional. But they did at least connect the ground to the metal bracket.
carl (not verified)
on Sep 7, 2012
the code requires a device box to carry the weight of the fixture.According to Art.300.15 a box is required at each splice point,outlet ,switch or termination point.
m hammer (not verified)
on Sep 7, 2012
somebody forgot the junction box...even a "pancake" box!
Mike Noelte (not verified)
on Sep 30, 2012
314.27 (A) (2) At every outlet used exclusively for lighting , the box shall be designed or installed so that a luminaire or lampholder may be attached.
Russ LeBlanc (not verified)
on Oct 27, 2012
Thanks for all of your replies!
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Feb. 28, 2011
video
Electrical Construction and Maintenance
Arlington Gangable boxes
Designed for new or retrofit applications, these snap-together gangable plastic boxes eliminate the need to construct a multiple-gang steel box out of several individual ones. Starting with a two-gang box, users can build the box they need in seconds, according to the company. For three-gangs or more, separate the box parts, add the center sections needed to make a new, larger box, and then snap the pieces back together. The UL-listed product is preset for ½-in. wall finish thicknesses....More
Newsletter Signup
Connect With Us
