What’s Wrong Here? Hint: Don't Blow a Gasket
Discuss this Article 9
Anonymous (not verified)
on Dec 6, 2012
No Strap
BXNPTWR (not verified)
on Dec 6, 2012
NEMA 1 cover in outdoor location.
Aaron (not verified)
on Dec 6, 2012
Nema 1 cover used in incorrect application (outdoor use). Sealtite not secured.
on Dec 6, 2012
no water sealing/rainproof gasket between box & conduit at top
Tom (not verified)
on Dec 7, 2012
Missing a gasket, and correct weatherproof plate sealtight is not straped to the buiding within 12 inches to the plate
on Dec 7, 2012
The cover is not a w/p and does not have a gasket.
on Dec 8, 2012
Not a weatherproof cover
mrsafetyman
on Dec 11, 2012
both the box and cover must be rated for Wet Location and yes sealtite needs to be supported with a strap I like 6 inches from box
on Dec 12, 2012
What about he flex rubbing against the brick edge? Is there a workmanship issue about protecting the plastic flex from being abraded away?
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington CED1 Entrance Hoods
The Scoop Series CED Entrance Plates and Hoods are reversible, non-metallic, single and two-gang versions...More
Newsletter Signup
Connect With Us
