What’s Wrong Here? Hint: Depth Perception
Discuss this Article 13
Anonymous (not verified)
on Nov 1, 2012
Box Fill? Appears kinda full from pic?
John Saporito (not verified)
on Nov 1, 2012
The box should had been replaced and set properly at the edge of the extented 2x4 and the use a plaster ring to meet the outer edge of the finished wall. If there was an electrician involved that electrician should had known better, and not to cut corners. Obviously the electrician involved doesn't know dittle about the NEC.
on Nov 1, 2012
Looks like a mud box was used instead of a box and plaster ring. Violation of 110.3B
on Nov 2, 2012
The face of the box should have been brought out flush as code requires. It appears that this is a remodel (looks like a k/o plug in thebottom left of the box.) It could have been brought out with an extension.
C. Kidder (not verified)
on Nov 2, 2012
What about that wiring behind the switch? Doesn't look like it meets the requirement of 110.12: "Equipment shall be installed in a neat and workman like manner".
RSlover
on Nov 2, 2012
The question should be:"What's right about this installation?" Box depth is the least of this installer's sins(wont call him/her an electrician). The rat's nest behind the switch is much more alarming.
on Nov 2, 2012
It needs extention ring for thedevice because of combustionable material it is hard to tell but maybe box fill is an issue.
E.EROH (not verified)
on Nov 3, 2012
Besides the setback violation it looks like the box may have too many conductors for its size.
Someone painted the switch which is not a violation but may impede its operation
Jose A. Guillen (not verified)
on Nov 5, 2012
Yes, the overspray of any paint or lacquer or anything contaminating electrical equipment is specified in Article 110, and it would be noted as not code compliant. I would report this overspray. Remember, paint is water based and water and electricity do not mix.
on Nov 5, 2012
314.20 states. In walls and ceilings constructed of wood or other combustible surface material, boxes, plaster rings,extension rings, or listed extenders shall be flush with the finished surface or project therefrom.
SUP2 (not verified)
on Nov 5, 2012
violation of 314.4, 314.20, 110.12, 110.12 A, 314.17A.
Mike Noelte (not verified)
on Nov 25, 2012
Besides 314.20 it also looks like the box is a masonary box which is not listed for that installation.
Dave Radford (not verified)
on Dec 12, 2012
You all are making assumption's, correct there is over spray on everything that makes this installation look in progress. Since everyone else is guessing I will too, I think that it is a remodel on a old structure were they did use a 2 gang masonry box on the original installation. Now that they have furd out the wall there will need to be an extension ring of some sort installed, with the ring installed, box fill should not be and issue.
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Sep. 14, 2012
Video
Electrical Construction and Maintenance
Arlington: Non-Metallic Floor Boxes
Arlington's Non-Metallic Floor Boxes give installers the fast and easy way to put a receptacle in the floor. Available for new concrete pours, installed floors, and adjustable boxes for all other new floor installations....More
Newsletter Signup
Connect With Us
