Ecmweb 6101 022014wwhpromo
What’s Wrong Here? Hint: Danger Island
Feb. 20, 2014
Hint: Danger island
I discovered this dangerous uncovered panel while I was visiting the Caribbean island of Antigua. I am not sure which electrical code is in effect on this particular island; however, I do know for sure that this is a great example of an NEC violation.
According to 110.27(A), energized parts of electrical equipment that operate at 50V or higher must be guarded against accidental contact by: enclosures or location in a room, vault or similar enclosure accessible to qualified persons only; screens or partitions where only qualified persons can access the live parts; or locating the equipment in an elevated position where only qualified people can access the equipment. Warning signs forbidding unqualified persons from entering those spaces must also be installed in accordance with the requirements of 110.27(C).
This open panel was not guarded or isolated in any way. In fact, any shopper or even a small child could easily reach directly into this panel intentionally or accidentally. Either way, making contact with these exposed energized parts could result in a deadly shock or an arc flash burn. This would be one sure way to ruin your vacation!
Russ LeBlanc | Owner
