What is in this article?:
first there's no cover on the panel and there is also how is a repair tech. going to work in the panel should a problem arise?
Aside from the obvious problem with al the co-ax in front of the panel, aren't those Sq. D contactors in the upper left supposed to be installed vertically? Also, I don't see any purpose in the loops in the panel feeders, other than being a possible source of dangerous impedance during a fault. I'd also like to know what the plastic device with wires extruding from the top is.
The surge suppressor may not be installed correctly.
I think the white plastic thing with the wires out the top is a cheap surge suppressor.
Lack of working clearance in front of panel
The receptacle is not GFI
The double lugging on the main lugs is also violating the NEC.
panel being use for storage locker as evidenced by bottle of gu in lower right corner
