Moving Violations Video No. 74, by Russ LeBlanc, NEC Consultant: Insufficient Receptacle Protection
Discuss this Video 3
on Jun 26, 2014
From the looks of the rust on the lock nut, this installation has been there for some time. Is it possible that when this receptacle was installed, it met current codes? You seem to imply that everything you find must meet the latest Code requirements.
on Jun 26, 2014
Keep in mind that this may not be a violation if it was installed prior to the Code having these requirements. The Code is not retroactive.
on Jul 1, 2014
I see two others have the same thought I did. As the installation appears to be existing, it may have been compliant at the time.
On the flip side, I found the requirement for the outlet cover being weatherproof whether a cap is plugged-in or not to be in each Edition going back to the 2002 NEC (oldest version I have at hand.)
Besides, appearing to be a ball park with young children present wouldn't it be a good idea to at least replace the cover so it is compliant?
Please or Register to post comments.
Electrical Testing Feed
EC&M Webinars
Nov 9, 2016
Webinar
Technology Enabled Data Center Life Cycle Services
This webinar will discuss the benefits of cloud connected data center monitoring, different levels of monitoring and the potential effects on availability and efficiency....More
Nov 2, 2016
Webinar
There is More to a Data Center than White Space; A Holistic Approach to Facility Monitoring and Control
EC&M Learning Center
Connect With Us
Sponsored Introduction Continue on to (or wait seconds) ×
