Moving Violations Video No. 48, by Russ LeBlanc, NEC Consultant: Violation of Section 300.20(B)
Discuss this Video 5
Anonymous (not verified)
on May 23, 2013
I would like to see him give me an example which shows the proper installation of these cables into a cabinet such as shown in the violation. How do I correct this? I am still unsure after seeing the video as I need to see exactly how to make the correction.
Bob Sechler (not verified)
on May 24, 2013
If you cut a slot between the individual holes that the cables bass through, with the cables laid out in the pattern shown in the video, it seems that the area in between the cables will fall out. So please demonstrate how this is done.
on Nov 4, 2013
You would have to cut out a square from the box and install a aluminum or other non magnetic material of appropriate thickness to cut the entrance holes into.
Russ LeBlanc (not verified)
on May 24, 2013
There appears to be a problem with the video. The rest of my explanation at the end of the video describes how to cut away the steel and attach a non-ferrous plate (eg. brass) to to the cabinet and connect the MI cables to the brass instead of the steel. This could be done when cutting slots is not an option due to the layout of the cables.
Richard Loyd (not verified)
on Jun 2, 2013
Slotting is allowed although I do not recommend it. I believe the best way is to cut a section of the panel wall out and replace it with a fiber plate so that there is not metallic separation.
Please or Register to post comments.
Electrical Testing Feed
EC&M Webinars
Nov 9, 2016
Webinar
Technology Enabled Data Center Life Cycle Services
This webinar will discuss the benefits of cloud connected data center monitoring, different levels of monitoring and the potential effects on availability and efficiency....More
Nov 2, 2016
Webinar
There is More to a Data Center than White Space; A Holistic Approach to Facility Monitoring and Control
EC&M Learning Center
Connect With Us
Sponsored Introduction Continue on to (or wait seconds) ×
