Moving Violations Video No. 29, by Russ LeBlanc, NEC Consultant, EC&M Magazine
Discuss this Video 5
Anonymous (not verified)
on Aug 9, 2012
So the bonding conductor has to be the same gauge as the conductor in the conduit. How would that even be possible??
on Aug 11, 2012
I would have used a 2-screw connector instead of a bonding bushing to terminate the conduit...
Steve Danielson (not verified)
on Aug 11, 2012
I watched your video on installing an electrical outlet with romex cable into a metal box and noticed a couple of issues and violations. First, the ground wire needs to be gounded to the metal box first and not through the receptacle ground strap.Grounding the box through the receptacle is a violation. Secondly, the metal adapter cover is just that, a cover, not a plate. When we say plate, we refer to a finished plate. Thirdly, the receptacle is not to be installed until the drywall is in place. That's because the receptacle ears are made to mount onto or lay flat on top of the drywall to secure the receptacle without being buried beneath it. If it buried beneath it, the receptacle would be hard to remove to access the wiring in the box.
Hope this helps,
Steve Danielson
Licensed Master Electrician
Russ LeBlanc (not verified)
on Aug 14, 2012
Steve, Where did you see this video? I've never made a video on that subject.
Russ
Ron (not verified)
on Aug 23, 2012
Are you sure it was a grounding electrode conductor and not supplemental bonding for information technology equipment or similar not intended to carry fault current but be only supplemental to the code required equipment grounding / bonding normally found in a circuit and covered by the NEC?
Please or Register to post comments.
Electrical Testing Feed
EC&M Webinars
Nov 9, 2016
Webinar
Technology Enabled Data Center Life Cycle Services
This webinar will discuss the benefits of cloud connected data center monitoring, different levels of monitoring and the potential effects on availability and efficiency....More
Nov 2, 2016
Webinar
There is More to a Data Center than White Space; A Holistic Approach to Facility Monitoring and Control
EC&M Learning Center
Connect With Us
Sponsored Introduction Continue on to (or wait seconds) ×
