Videos
RSS
  • Apr. 15, 2013
    video
    The Westex Difference
  • Apr. 15, 2013
    video
  • Apr. 15, 2013
    video
    Protection From Arc Flashes
    Learn how arc flashes happen, how they are measured and how wearing the right flame resistant clothing can keep workers safe....More
  • Oct. 17, 2012
    video
    MENNEKES ® AMAXX Easy One-man Installation
    This video demonstrates the easy, one-man installation of an MENNEKES ® AMAXX unit. See how these custom power distribution units can save you time, money and space....More
  • Sep. 14, 2012
    Video
    Electrical Construction and Maintenance
    Arlington: Non-Metallic Floor Boxes
    Arlington's Non-Metallic Floor Boxes give installers the fast and easy way to put a receptacle in the floor. Available for new concrete pours, installed floors, and adjustable boxes for all other new floor installations....More
  • Mar. 2, 2011
    video
    Arlington TV Bridge
    Arlington's TV Bridge includes two recessed power/low voltage combo boxes and all the connections you need (except for the NM cable) to install a flat screen TV in an existing wall. The best part is there's no need to run cable from a panel box - or cut holes in your framing members. Just cut two holes in the wall and access power from an existing, nearby source....More
  • Feb. 28, 2011
    video
    Arlington Gangable boxes
    Designed for new or retrofit applications, these snap-together gangable plastic boxes eliminate the need to construct a multiple-gang steel box out of several individual ones. Starting with a two-gang box, users can build the box they need in seconds, according to the company. For three-gangs or more, separate the box parts, add the center sections needed to make a new, larger box, and then snap the pieces back together. The UL-listed product is preset for ½-in. wall finish thicknesses....More
  • Feb. 28, 2011
    video
    Arlington FBRS4200R
    Arlington’s extra heavy-duty, plated steel fan/fixture box now has higher weight ratings…150 lbs for fixtures and 70 lbs for fans…when installed on joists spaced 16” on center…and 70 lbs for either a fan or fixture on joists spaced 24” on-center!...More
  • Feb. 28, 2011
    video
    Arlington CP9000
    Arlington’s new 9” diameter ceiling cover plate is the neatest way to cover unused “high hat” cans. With no tools needed, installation couldn’t be faster! CP9000’s spring anchor brackets slip between the turned down metal tabs inside the “can” or directly to the “can”....More
  • Jan. 7, 2011
    video
    Arlington non-metallic 8161 Series Boxes
    Arlington’s non-metallic 8161 Series Boxes offer installation options for cameras and more, indoor or outdoor, for wet or dry locations...More
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
Newsletter Signup
Connect With Us
