Fluke Corp. is voluntarily recalling certain Fluke 373, 374, 375, and 376 digital clamp meters. If you own one of these clamp meters, please stop using it immediately and send it back to Fluke for repair.
Fluke Corp. Recalls Digital Clamp Meters
Jan. 29, 2013
Fluke Corp. is voluntarily recalling certain digital clamp meters that were manufactured between Sept. 1, 2010, and Oct. 31, 2012.
Name of products: Certain Fluke 373, 374, 375, and 376 Digital Clamp Meters
Manufacturer: Fluke Corp.
Hazard: The printed circuit assembly in these units may not be properly fastened to the test lead input jack. This may result in inaccurate voltage readings, including a low or no voltage reading on a circuit energized with a hazardous voltage, presenting a shock, electrocution, or thermal burn hazard.
Description: This voluntary recall involves Fluke Digital Clamp Meters with the model and serial numbers listed below. Any serial number preceded or followed by the letter “R” is not affected by this recall notice.
Model
Manufacture Dates
Starting Serial Number
Ending Serial Number
Fluke 376
Sept 2010 – Feb 2011
14270001
15909999
Fluke 375
Sept 2010 – Mar 2011
14270001
16079999
Fluke 374
Oct 2010 – Feb 2011
14270001
16379999
Fluke 373
Oct 2010 – Oct 2012
14270001
21950000
If you own one of these clamp meters, please stop using it immediately and send it back to Fluke for repair. If someone else within your organization is the primary user of the Fluke 37X Series Clamp Meter or is responsible for responding to recall notices, please pass this notice along to the appropriate person. (Please send only the clamp meter; any test leads/boxes/manuals that are sent with the unit will not be returned.)
Contact Fluke for information on how to have your units repaired:
  • Visit www.fluke.com/37x-recall to register your affected product online as part of the recall. Once your information is complete and you click “submit,” a postage-paid mailing envelope will be sent to you within two business days. Use this envelope to return your clamp meter to Fluke for repair. Your clamp meter will be sent back to you when repairs are complete.
  • Call (877) 564-7180 for information and to request a postage-paid mailing envelope be sent to you.
Strut Comparison Chart
Strut Corrosion Guide
