Product Categories
The EC&M Product of the Year competition will recognize winners in up to 22 categories.
  • Boxes & Enclosures
  • Computers & Software
  • Conduit, Raceways & Wireways
  • Connectors, Fittings & Terminating Devices
  • Fasteners, Hangers & Accessories
  • Lamps & Ballasts
  • Lighting Fixtures
  • Lighting Systems
  • Monitoring Instruments
  • Motors, Drives & Motor Controls
  • Power Conditioning Equipment & Protective Devices
  • Power Distribution Equipment
  • Power Sources
  • Protective Devices
  • Safety Equipment
  • Security Equipment & Systems
  • Specialty Products
  • Test Instruments
  • Tools & Equipment
  • Voice/Data/Video Equipment
  • Wire & Cable
  • Wiring Devices
  • Want to use this article? Click here for options!
    Acceptable Use Policy
what's wrong here?
May 10, 2012 12:44 PM
Apr 19, 2012 10:09 AM
Apr 5, 2012 2:27 PM
View all What's Wrong Here?
product spotlight
EV charger tester
May 25, 2012 8:26 AM
EV charger tester
Free Product Info
Recent Comments
More...
Social Media
More ways to stay informed...
follow us on twitter
Find us on Facebook
2011 Winner
The 2011 platinum award winner, comes from the portable measurement equipment category and proves that improved flexibility and safety can be combined in one product. The Fluke 381 clamp meter is the first with an iFlex flexible current probe and a detachable, remote display for easier, faster, safer remote measurements. Both the clamp meter and probe are rated for hazard 1,000V CAT III and 600V CAT IV environments.
2011 Gold Award: The first runner-up in this year's Product of the Year competition comes from the tools (accessory items) category. Greenlee, a Textron Co.'s Nail Eater R/T features a replaceable tip that cuts more than 175 holes in wood with nails, which the company says is nine times the life of a traditional auger bit. The product's cutting edge is made from high-quality tool steel for enhanced performance. The replacement kit includes the new tip, a set screw, and a hex wrench.
2011 Silver Award: From the wire and cable category, this year's second runner-up, Southwire's SIMpull Stack, allows users to combine multiple pulls on one single reel. According to the company, one reel can hold up to five phases, for up to four pulls, depending on the size of the cable and length of the pull. For multiple runs in a pull, users just remove the shrink wrap, pull the first run, then pull the second, third, etc., without having to set up additional reels.
More 2011 category winners
2010 Winner
The 2010 platinum award winner, comes from the conduit fittings category and proves that a simple device can prevail in a high-tech world. The Electrical Bypass is a patented, disposable device designed to provide electrical and communications contractors with an easier way to install conductors with multiple junction boxes when using conventional snake/wiring methods. In addition, the product also allows users to use a mouse and string setup to blow or vacuum a line from beginning to end of the conduit.
2010 Gold Award: The first runner-up in this year's Product of the Year competition comes from the computers and software category. Simutech Multimedia, Inc.'s Troubleshooting Skills Series V4 software is a simulation-based troubleshooting training system that helps users develop skills for troubleshooting a variety of electrical circuits and equipment.
2010 Silver Award: The second runner-up in this year's competition is Eaton Corp.'s Arc-Resistant Low-Voltage Switchgear. This ANSI Type 2 arc-resistant, low-voltage switchgear protects operating and maintenance personnel from dangerous arcing faults by redirecting or channeling the arc energy out the top of the switchgear, regardless of the origination location of the arc.
More 2010 category winners
2009 Winner
The 2009 platinum award winner, confirms the adage that sometimes two are better than one. The Tamper-resistant nightlight/GFCI combination device from Syracuse, N.Y.-based Pass Seymour/Legrand (P&S) aimed at residential homeowners, the product incorporates an LED nightlight into a tamper-resistant duplex ground-fault circuit interrupter (GFCI), meeting 2008 NEC standards for child electrical safety in newly constructed single- and multi-family dwellings.
2009 Gold Award: The first runner-up in this year's Product of the Year competition came from the luminaires (indoor/LED) category and went to Juno Lighting for its LED downlight. This recessed LED downlight features 5-in. and 6-in. LED housings available in new construction and remodel styles.
2009 Silver Award: The second runner-up in this year's competition was Ideal Industries' TKO hole cutters in the tools (hand/accessory) category. TKO carbide tipped hole cutters are designed to cut sheet metal and stainless steel.
More 2009 category winners
2008 Winner
2008 platinum award winner: People say change is hard, but EC&M's 2008 Product of the Year winner is helping to dispel this common notion. EverLED TR from Randolph, Vt.-based LEDdynamics is a direct "drop-in" replacement for standard fluorescent tubes that uses the existing fluorescent ballast of a luminaire. According to the company, the product is compatible with most standard ballast-equipped fluorescent light fixtures, including lenses, reactive and electronic ballasts, and programmed/instant/rapid/trigger start.
2008 Gold Award: Adjustable Mud Ring. The first runner-up in this year's Product of the Year competition came from the boxes category and went to Thomas & Betts for its Steel City adjustable mud ring. The product ensures that stud-mounted outlet boxes fit flush with any thickness of finished drywall, plaster, or ceramic tile, according to the company.
2008 Silver Award: LED Linear Lighting. The second runner-up in this year's competition was Juno Lighting Group's Trac 12 LED in the lighting fixture category. Juno Trac 12 TL201LED low-power LED's consume less than 15% of the power of conventional 5W low-voltage xenon lamps, according to the company.
More 2008 category winners
2007 Winner
2007 platinum award winner, comes from the KO Stamp from Deviser won EC&M's 2007 contest by a knockout. This marking device for conduits helps electricians find the center points and conduit sizes to be installed in an electrical enclosure. According to the company, the device cuts layout time by 98%. To use, place the stamps into the electrical conduits, ink the tops of them, and then place the box on top of the stamps to accurately imprint center point and conduit size.
2007 Gold Award: The first runner-up in this year's Product of the Year went to Carlon/Lamsom & Sessions for its Metal Adjust-A -Box. This product allows the installer to adjust the box to any wall thickness with the turn of a screw. Clip onto the stud, and then turn the screw to adjust the box in or out to make it flush with the finished wall.
2007 Silver Award: The second runner-up in this year's competition was Fluke's 117 Digital Multimeter in the portable test & measurement equipment category. This device includes integrated VoltAlert non-contact voltage detection, which quickly senses the presence of AC voltage and provides a visual indicator to determine proper grounding.
More 2007 category winners
2006 Winner
2006 platinum award winner: Short on features, but long on practicality, the One-Box non-metallic outlet box from Arlington Industries garnered the most votes from EC&M readers, securing the Platinum Award in the magazine's 2006 Product of the Year competition. The One-Box is designed for new construction or retrofits and mounts securely to a wood or steel stud via its captive angled screws. If the box is set too far forward or too far back, you can easily back out the screws and reposition them for new work. In old work applications, the box mounts to the stud — not the drywall (as do boxes designed with wing brackets) — which enhances the structural integrity of the overall unit upon final installation. Read more about the top three products.
More 2006 category winners
2005 Winner
2005 platinum award winner: Proving the age-old adage that good things come in small packages, the Space Saver EMT Set Screw and Compression Connector from Cooper Crouse-Hinds garnered the most votes from EC&M readers to secure the Platinum Award in the magazine's 2005 Product of the Year competition.
2005 Gold Award: The first runner-up was the 700 series of 600A and 1,000A industrial clamp meters with TightSight display from Ideal Industries.
2005 Silver Award: The second runner-up was Southwire Co.'s Romex SIMpull tear-resistant, reduced friction nonmetallic Type NM-B cable.
More 2005 category winners
2004 Winner
2004 platinum award winner: EC&M awarded Pass and Seymour/Legrand the 2004 Product of the Year Platinum Award for its Trademaster Decorator Combination Devices.
2004 Gold Award: The second and third place runners-up are MGE UPS Systems' Evolution Nexa RM Fuel Cell UPS and 2004 Silver Award: KO Instruments' CBA1000 Circuit Breaker Analyzer.
More 2004 category winners
2003 Winner
2003 platinum award winner: Drill-spotting tool helps electricians take the guesswork out of drilling EC&M readers select the First Edition Products DrillSpotter as the 2003 Product of the Year. Learn about the 20 finalists.
More 2003 category award winners
2002 Winner
2002 platinum award winner: Encore's Color-Coded Cable. Encore Wire Ltd., McKinney, Texas, expanded its line of color-coded wire and cable to NM-B, THHN and XHHW-2 building wire. Each wire size now comes in a different color. Encore Wire introduced its colored wire and cable for the commercial market in 1999 to help contractors with installation and inspection, simplify inventory management and provide a safer, more efficient work environment.
More 2002 category award winners
2001 Winner
2001 platinum award winner: Generac's Power Player. Powered by natural gas and offering remote control and monitoring, the DG 50 generator offers small retail and commercial users a one-two punch -- 50kW of backup power during blackouts or power interruptions and an on-site power source that can help them slash their electrical bills by managing their power consumption and feeding excess power to the utility grid.
More 2001 category award winners
Browse Back Issues
Browse Back Issues
