New Products, January 2012
Motor Control Centers
The Tiastar motor control center (MCC) product line now includes four arc-resistant models compliant to ANSI/IEEE C37.20.7. The MCCs feature a SmartStart option with plug-and-play functionality to reduce commissioning time with pre-programmed and pre-configured data. High-density designs meeting UL and NEMA standards, while reducing unit size for NEMA 1 through starters, allow for up to a 10% weight reduction and offer a 25% smaller footprint, according to the company.
Siemens Industry
Circle 250
Aluminum Hubs
This line of die-cast aluminum hubs securely connects rigid metal conduit (CRMC) or intermediate metal conduit (IMC) to the threadless opening in an enclosure, providing a NEMA 4X watertight seal. In addition to standard environments, the devices can be installed in hazardous industrial locations. Available trade sizes range from ½ in. to 2 in. in grounding and non-grounding styles. A PVC coating is available on select hubs.
Appleton
Circle 251
Adjustable Variable Ring
This adjustable variable ring (AVR) for electrical junction boxes offers a pre-fab solution that ensures a flush fit while eliminating the need for multiple plaster rings. The AVR includes a sliding insert in a box-shaped frame that allows adjustments from ½ in. to 2 in. Featuring a measuring rule, the insert slides in and out of the base frame with a ratcheting mechanism. In addition, the sliding mechanism allows for modifications. When installation is finalized, the AVR is easily and quickly removed.
Orbit Industries/UMI
Circle 252
Support Tool
Similar to a machinist v-block, the Ladder Horse is designed for supporting, cutting, trimming, and sawing a variety of materials. Unlike a sawhorse, the product requires no unfolding, no assembly, and no storage. Users can choose the ladder rung that offers the best height for them to stand up and cut from. Features include aluminum construction and marked measurements.
Madison Electric Products
Circle 253
Pop-up Receptacle
The Carlon Kitchen Pop-up receptacle eliminates power cords hanging over the edge of the counter to reach side-mounted outlets. When not in use, the receptacle is hidden beneath the countertop surface with only a 4¾-in.-diameter metallic cover visible. When the cover is pressed down slightly, the GFCI receptacle pops up above the countertop. Available in nickel, bronze or brass finishes, the 15A, 125VAC/60Hz product features gaskets fitted under the flange and around the main body to prevent spilled liquids from penetrating the electrical enclosure when the receptacle is open or closed.
Thomas & Betts
Circle 254
Line Laser
The DW089K features a second plumb line that forms a 90° intersecting line on the floor and ceiling. This third vertical beam allows users to employ the tool for layout applications without the need for a second laser. For commercial wall layout applications, the product offers a track clearance of more than 1¾ in., eliminating the need for additional accessories to raise the laser over drywall track. According to the company, the tool is accurate within 1/8 in. at 30 ft.
DeWalt
Circle 255
Conduit Bodies
Type X conduit bodies allow users to run wire and cable in multiple directions. Manufactured from type 316 stainless steel, the conduit bodies are corrosion-resistant and suitable for use in marine and sanitary applications. Available sizes include ½ in., ¾ in., 1 in., 1½ in., and 2 in. According to the company, the four-hub “X” configuration limits the amount of additional fittings needed on a project, as wires can be fed through and then out in several directions. A cover and gasket set are also included.
Calbrite
Circle 200
Power Distribution Units
Advanced Monitored and Managed enclosure power distribution units (ePDUs) are designed to provide monitoring and control power consumption at the individual outlet level. Both models monitor critical factors such as voltage, current, and power factor. The outlet number identifications are color coded to match the outlet section to the appropriate circuit breaker. In addition, the Managed models are designed to provide full control of each outlet, allowing users to remotely switch the outlet on/off or reboot. Available in 14 configurations with eight different input plugs, the ePDUs feature 200V to 240V power output to C13 and C19 outlets.
Eaton
Circle 201
Continue to page 2
Acceptable Use Policy
what's wrong here?
May 10, 2012 12:44 PM
Apr 19, 2012 10:09 AM
Apr 5, 2012 2:27 PM
View all What's Wrong Here?
product spotlight
EV charger tester
May 25, 2012 8:26 AM
EV charger tester
Free Product Info
Recent Comments
More...
Social Media
More ways to stay informed...
follow us on twitter
Find us on Facebook
EC&M Whitepaper
Date: Wednesday, May 30, 2012
Time: 2:00pm ET
Grounding Versus Bonding
Now Available On-Demand
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
industry links
industry links
rss icon
rss
Browse Back Issues
Browse Back Issues
