Focus on Motors
Spotlight on motors for electrical contractors, electrical engineers, and plant facility personnel
DC motors
The IronHorse permanent magnet DC 56C-frame motor line features totally enclosed non-vented (TENV) and totally enclosed fan-cooled (TEFC) models. The motors are constructed of a rolled steel frame with cast aluminum end bell and are available in sizes ranging from 0.33 hp to 2 hp. Featuring a base 1,800 rpm, the product is designed for use on unfiltered SCR- (Thyristor-) type 115V or 230V rectified AC inputs when used with an appropriate SCR drive. They can also be used with pulse-width modulated- (PWM-) type DC adjustable-speed drives.
Automation Direct
Circle 300
Electricity usage software
Available as an application for iPhones, BE$T software calculates an existing motor's annual electricity usage based on its nominal efficiency and compares it to the annual electricity usage of the company's Standard-E and Super-E premium efficiency motors. The software then recommends, by catalog number, the appropriate motor for the application and notes the payback period (in months) for replacing the existing motor. Available in CD-ROM format or as a download from the company's website, the product can calculate the savings on a group of motors, showing the amount of money that can be saved when all motors in the group are replaced.
Baldor Electric
Circle 301
Gearhead
The WX high-torque gearhead features an exterior that is identical to the company's old W models with a redesigned interior. According to the company, the gearmotors feature all-new steel helical gears and synthetic lubricant, allowing them provide up to 50% more torque than previous models. The gearing is designed to AGMA 9 standards or higher, and the synthetic lubricant allows the unvented gearmotors to operate over a wide temperature range. Gear ratios range from 4-to-1 to 312-to-1.
Bodine Electric
Circle 302
Low-vibration motor
According to the company, the redesigned SD100 IEEE841 motor surpasses the requirements of IEEE Std 841-2009, which requires 3,600-rpm motors to operate with a maximum filtered vibration of .05 in./sec at twice speed or twice line frequency. Available in three configurations, product features include a cast-iron frame, bearing housings, fan cover and conduit box, double-drilled (eight mounting holes) feet, 6-bolt bearing housings, NEMA Premium or higher efficiencies, and Inpro/Seal bearing isolators on both ends of the motor.
Siemens
Circle 303
Acceptable Use Policy
what's wrong here?
May 10, 2012 12:44 PM
Apr 19, 2012 10:09 AM
Apr 5, 2012 2:27 PM
View all What's Wrong Here?
product spotlight
EV charger tester
May 25, 2012 8:26 AM
EV charger tester
Free Product Info
Recent Comments
More...
Social Media
More ways to stay informed...
follow us on twitter
Find us on Facebook
EC&M Whitepaper
Date: Wednesday, May 30, 2012
Time: 2:00pm ET
Grounding Versus Bonding
Now Available On-Demand
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
industry links
industry links
rss icon
rss
Browse Back Issues
Browse Back Issues
