Product Literature
Jun 1, 2005 12:00 PM, By EC&M Staff
New catalogs, brochures and information from our advertisers
New Construction Grade Leaded Wiring Devices
New leaded devices speed commercial installation! Pass & Seymour/Legrand announces the introduction of its new pre-wired construction grade leaded wiring devices with six-inch welded wire leads. The new leaded devices create faster, more reliable connections for use in the pre-fabrication, office, multiple-dwelling and retail building applications. For more information, visit www.passandseymour.com.
Circle 401 on Reader Service Card • freeproductinfo.net/ecm
Current Transformers, Transducers and Accessories
Catalog No. 2011 is a 170-page catalog
featuring split- and solid-core current transformers; potential transformers; transducers for AC or DC; analog and digital panel meters; current probes; current relays; KWH submeters; Power meters; and analog to pulse converters. To contact FLEX-CORE:Ph: (614) 889-6152; Fax: (614) 876-8538;
E-mail: flexcore@msn.com; www.flex-core.com
FLEX-CORE
Circle 402 on Reader Service Card • freeproductinfo.net/ecm
Lutron’s Ecosystem™ Redefines Fluorescent Lighting Control
Lutron’s new EcoSystem™ solutions provide daylighting, automated energy management, and personal control in a cost-effective system. Lutron’s EcoSystem fluorescent lighting control products make florescent lighting control easy to design, easy to install, and easy to maintain for any size project. The EcoSystem ballast won the Best of Category Award for Ballasts and Transformers at Lightfair International 2005. For more information, visit www.lutron.com or call 877.258.8766.
Lutron Electronics
Circle 403 on Reader Service Card • freeproductinfo.net/ecm
CADDY® SPEED LINK LD Universal Support System
CADDY® SPEED LINK LD is a universal support system that quickly suspends static loads, even at an angle. It is a cost-effective alternative to jack chain, threaded rod and associated hardware in lighting and other applications. The 1.5 mm wire rope holds loads of up to 20 kg (44 lb). A small, aesthetically pleasing locking device completes the assembly.
1-800-25-CADDY • www.erico.com
Erico, Inc.
Circle 404 on Reader Service Card • freeproductinfo.net/ecm
SafetyPlugs & Receptacles
Use Meltric safety plugs to connect motors and other equipment up to 200A. Safety plugs feature an integral switching function that ensures that the plug is dead before withdrawal. An electrically safe work condition is further ensured by the device’s dead front and its 100 kA short circuit make and withstand ratings. Safety plugs lower costs and simplify NEC and OSHA/NFPA 70E compliance. Free samples are available.Ph: (800) 433-7642; E-mail: mail@meltric.com; Web: www.meltric.com
Meltric Corporation
Circle 405 on Reader Service Card • freeproductinfo.net/ecm
Meter-Rite® Double-Throw Switches
RONK METER-RITE® manually operated Double-Throw Switches for stand-by power systems are available in both pole-top and grade-level styles, single or 3-phase. Grade-level switches are available with ratings from 100A to 800A. Pole-top switches are available with ratings from 200A to 800A. Switches are available with either 250V or 600V ratings. UL listed and Center-Off units available in 250V.
Ph: (800)-221-7665, ext. 141
www.ronkelectrical.com
Ronk Electrical Industries, Inc.
Circle 406 on Reader Service Card • freeproductinfo.net/ecm
New Catalog: Surge Protection for AC Power Lines
MCG Surge Protection has issued a new 20-page full color catalog entitled, “MCG Surge Protection for AC Power Lines.” The catalog features a comprehensive user’s guide that shows Anatomy of a Lightning Strike, patented Micro Z Concept for exceptionally low impedance, and Coordinated Protection Recommendations for appropriate protector placement at the Cat A, B, and C locations. Learn more at: www.mcgsurge.com.
Circle 407 on Reader Service Card • freeproductinfo.net/ecm
New Products Featured in Test & Measurement Instruments Catalog
Over 12 new products are featured in the AEMC® 60-page catalog which highlights AEMC®'s lines of portable test and measurement instruments, including megohmmeters, ground resistance testers, power quality analyzers & meters, cable testers, current probes, multimeters, data loggers, environmentatesters, test tools & more. Ph: (800) 343-1391; Email: sales@aemc.com; Catalog also
available online at www.aemc.com.
AEMC® Instruments
Circle 408 on Reader Service Card • freeproductinfo.net/ecm
Fiberglass Conduit Bodies
After years of research and development, Champion Fiberglass, Inc. is extremely proud to introduce their new line of conduit bodies. Molded from fiberglass, these new fittings, combined with Champion’s fiberglass conduit, complete a totally nonmetallic conduit system, ideal for applications in corro-sive environments. Available in sizes 3/4-2”. Ph: (281) 655-8900; Email: info@championfiberglass.com; www.championfiberglass.com
Circle 409 on Reader Service Card • freeproductinfo.net/ecm
ERITECH® Direct Burial Ground Clamp
The ERITECH® EK16 & EK17 Direct Burial Ground Clamp is a versatile bronze-alloy clamp that consolidates a rebar, ground rod, water pipe and direct-burial water pipe clamp into one product. It is ideal for swimming-pool grounding, light poles and direct-burial applications. The UL-listed product cuts installation time by allowing the clamp to be pre-set on rebar or pipe.
1-800-677-9089 • www.erico.com
Erico, Inc.
Circle 410 on Reader Service Card • freeproductinfo.net/ecm
www.NECcode.com
NEC Internet Connection is constantly updated with up-to-the-minute information about the National Electrical Code. Visit to gain access to FREE online training, software, graphics, videos, booklets and simulated exams. Register for a FREE newsletter.
Mike Holt Enterprises
Circle 411 on Reader Service Card • freeproductinfo.net/ecm
EC&M Literature Review/Marketplace
Each month, EC&M compiles a comprehensive section dedicated to promoting catalogs, brochures, and product information.
The EC&M Literature Review/Marketplace gives our 140,000+ subscribers the opportunity to request detailed information about your products, and provides you with valuable sales leads. You can now receive additional exposure online when your ad is featured on www.ecmweb.com! Contact your local sales representative for more details.
Circle 412 on Reader Service Card • freeproductinfo.net/ecm
© 2008 Penton Media, Inc.
advertisement
product of the week
Lighting control system
August 25, 2008 8:41 AM
