ECM Buyers' Guide
Product News
Sep 1, 2001 12:00 PM, By EC&M Staff
Cable management system
The Network Cable Manager system includes two varieties of durable molded plastic horizontal panels, designed to manage high-performance copper and fiber cables on standard EIA 19-in. racks.
Panduit
Circle 158
Fiber optic duct repair kits
These heavy-duty duct repair kits are designed for conduits carrying fiber optic cable. The kits come with heavy-walled split conduit, hose clamps, cable ties, and a patented sealing system for retrofitting without removing the cable from service. Each kit handles a variety of fiber optic duct dimensions.
Jackmoon USA
Circle 161
Programmable logic controller
Release 1.1 of the VersaMax Ethernet network interface unit features embedded Ethernet connectivity without the need for a serial connection from a PC or handheld device. The unit is now compatible with this company's series 90 PLCs using Ethernet Global Data.
GE Fanuc Automation
Circle 192
Data line surge protectors
These data line surge protectors use sideactor and silicon-avalanche diode-based circuits exclusively. With turn-on times measured in the nanosecond range, they are appropriate for the high-speed and bandwidth requirements found in today's sophisticated networks.
Cylix
Circle 191
Coaxial cable stripper
This ergonomically designed Cat. 5 coaxial cable stripper tool gives installers a quick and easy method of preparing RG-6 or RG-59 coaxial cable for termination. Made from durable, high-impact Delrin plastic, the tool features a long-life cutting blade to accurately cut coaxial cable sheath without causing damage to the internal components of the cable.
ICC
Circle 160
Multiwire data line protector guard
The DLP-50 can protect as many as 50 wires of telco equipment from damage or disruption caused by transient overvoltages. The 3.3 in.×3.4 in.×1-in. unit protects equipment such as T1, E1, PABX, and multiplexers. Its silicon-avalanche diodes allow close transient clipping in less than 1 ns.
MCG Surge Protection
Circle 179
Uninterruptible power system
The Pulsar Ellipse UPS features high-frequency switching technology in small packages for backup power to PCs and workstations. The switching technology eliminates bulky, heavy transformers. The product is available in power ratings from 300VA to 1,200VA. The UPS is best suited for maximizing the availability of PCs, workstations, and small servers.
MGE UPS Systems
Circle 201
Fastening feature for notifiers
The QuickClick fastening feature will be phased into SpectrAlert wall-mount notification devices this year. The feature eliminates the need for mounting screws to secure the device to the mounting plate. Instead, you hinge the housing toward the mounting plate until it clicks into place.
System Sensor
Circle 221
Three-channel controller
The MR13 is a three-channel, multi-input, multirange, user-programmable controller. It can be used as a three-zone controller, follower controller, or cascade control. It incorporates EXPERT PID, which suppresses hunting caused by overshoot or process disturbance.
Vespo
Circle 237
Relay modules
The flare series of DIN rail-mounted terminal block relay modules provides time-controlled or delayed-switching functions. The modules are packaged in 6.2-mm thick, UL94 V-0-rated polyamide 6.6 housings. They feature 2-pole pluggable jumpers and 10-pole comb jumpers to reduce wiring time.
Wieland Electric
Circle 235
Single-phase power monitor
The Power Platform 4300 power monitoring instrument comes equipped with a TaskCard, allowing it to operate in four modes — scope mode, for real-time viewing of waveforms; meter mode, for second-by-second measurements of up to 16 parameters; an event-recorder mode that allows you to view recorded event data for immediate problem solving and troubleshooting; and a time-plots mode that allows you to graph and display measurements.
Dranetz-BMI
Circle 215
The Model DPE300E 3-phase delta conversion UPS features reliable power protection at a low cost. The UPS reduces the cost of energy consumption, installations, wiring, air-conditioning, and maintenance. The UPS's primary function is supplying clean 3-phase power to critical applications, data centers, and facilities, regardless of power failures, sags, surges, brownouts, line noise, high-voltage spikes, frequency variations, or switching transients. The product is designed to proactively identify and correct power problems to prevent downtime.
American Power Conversion
Circle 202
Colored cables
These customized color cables can be used to make complicated installations easier, faster, and safer. Double-jacketed, double-colored cables are available. The company can print serial numbers, corporate logos, and brand names on the jackets.
elocab
Circle 208
Busway suppression filter system
GuardBus is a direct-connect busway suppression filter system that protects critical loads from electrical disturbances. Models will plug into GE, Spectra series, Siemens XL-X, Square D I Line II, or Cutler-Hammer/Westinghouse Model 5 or 6 busplugs. The UL-listed, safety-interlocked, fused disconnect switch permits testing without interrupting power.
Current Technology
Circle 229
Circuit breakers
Series B push-to-reset circuit breakers meet the motor loading requirements of UL's 1363, Standard for Relocatable Power Tap. They are rated at 125VAC to 250VAC with current ratings from 5A to 20A. Interrupt capacity is 1,000A or 2,000A, depending on voltage/current.
Rototech Electrical Components
Circle 249
Hand lamp
Designed to provide customers with portable lighting in hazardous locations, this 26W fluorescent lamp is UL-listed for use in oil refineries, chemical-processing plants, waste-treatment centers, and other classified sites. The explosion-proof, twin-tube lamp delivers 1,800-lm output and easy maintenance in a 3½-lb, 23½-in.-long design.
McGill
Circle 254
Screwdriver
The 6-in-1 TriLobal multi-screwdriver comes with four screwdriver bits that fit in a durable steel barrel. The barrel doubles as a nut driver; each end incorporates a different size driver. The handle fits the contour of your hand.
OXO
Circle 276
Cart for pipe benders
The Bendcart BC-100 converts this company's 885T EMT bender or 881 combination bender into portable bending centers. The cart measures 56 in.×30 in. and fits through most doors and onto trucks and elevators. Shoes mount on the back for easy access.
Associated Electric Products
Circle 277
Progressive-pitch saw blades
These progressive-pitch reciprocating and jigsaw blades are designed to eliminate the need to change blades when cutting materials of different thicknesses. The closely spaced teeth near the blade's shank provide speed and control when cutting thin materials, and the wider-spaced teeth near the blade's tip are more suited for thick materials.
Greenlee Textron
Circle 260
Corded drills
These corded drills come in ½-in., ⅜-in., and ¼-in. sizes. Lightweight but powerful, they are designed for comfort and balance with large, two-finger triggers and tactile handle grips. All ½-in. and ⅜-in. models come with a 360° side handle for additional comfort and tool control.
Milwaukee Electric Tool
Circle 269
product of the week
Evaluation Software
December 1, 2008 9:59 AM
Honeywell Power Evaluation Software
Recent Comments
Follow comments on ecmweb.com
Do you have any technical paper explaining IBC?
I-Gard
Retrofit 2-Gang TV Box(TM)
Arlington’s recessed two-gang TV BOX™ for old work allows you to mount LCD and plasma TVs, and other system components flush against the wall.
Listen
Listen
Sponsored By:
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
rss icon
rss
Back to Top
Browse Back Issues
Browse Back Issues
