Product News
Oct 1, 2001 12:00 PM, By EC&M Staff
Notification circuit expander
The PAD-3 notification circuit expander is designed for use with
Cerberus Pyrotronics' fire alarm control panels. It has built-in
synchronization capabilities and is UL-listed for 24VDC applications.
It offers a 3A auxiliary output for driving portions of fire alarm
systems such as door holders.
Siemens, Cerberus Division
Circle 228
Service entrance protection
The Critec SES 200 for service entrance standard protection features
patented transient discriminating (TD) technology that ensures long
life under adverse conditions and meets the standards of UL 1449
Edition 2. Its diagnostics panel allows users to monitor the operating
status of protection for all equipment.
ERICO
Circle 247
Energy management software
RSEnergy Version 2.0 is Web server-based software that monitors
energy use throughout a network, providing real-time and historical
data on energy usage. The program allows users to create custom rate
plans with a rate plan wizard tool.
Rockwell Automation
Circle 230
Portable analyzer
The HTS-771-P2DU portable power diagnostic unit combines the
benefits of a combinational logically-programmable electric power data
logger with a power quality analyzer. Self-powered, high-speed status
inputs allow discrete time-stamped event logging and the capture of
pre- and post-event waveforms upon transition of circuit breaker
auxiliaries or other dry contacts.
Hanover Technical Sales
Circle 245
Sealed control stations
This line of factory-sealed XFS control stations is appropriate for
indoor or outdoor applications where Class I or Class II hazards are
present, such as petroleum refineries, chemical plants, and
grain-processing/storage facilities.
Adalet
Circle 214
Cable-anchoring tool
With the StrapGun, contractors can install 12/2 and 14/2 nonmetallic
sheathed cable with one hand. The lightweight, all-steel tool installs
the company's insulated, UL-listed straps in one shot. Its guide system
properly positions the strap over the cable.
Powerfast
Circle 241
Cable management rack
The Mighty Mo 4Mation four poster cable management rack supports
servers of almost any brand or size, making it suitable for
applications such as data centers, ISP installations, co-location
facilities, and other commercial installations.
Ortronics
Circle 163
FM fiber optic video system
The NTK3610 and NTK3810 series frequency-modulated fiber optic video
transmission system is designed for security surveillance and
intelligent transportation. Multimode versions employ 850 nm and 1300
nm LEDs. Standalone field units are compact and powered by 12VDC or
24VAC.
NTK NewTek
Circle 171
Cabling system for modular furniture
The DATATHING Panel-to-Panel Cabling System is now available in a
variety of Haworth modular furniture systems. It is designed to restore
flexibility to modular office furniture and facilitate moves, adds, and
changes — while providing the high performance demanded by
today's networks.
KRONE
Circle 155
Hand-held test set
The Model 77 BERT hand-held test set tests sync and async WANs
running at data rates from 10 bps to 10 Mbps. It offers fifteen
interface modules, including RS-232-C, V.35, RS449B, EIA-530, X.21, DDS
and Fractional T1/E1 with Drop and Insert.
International Data Sciences
Circle 195
PVC jacket for coaxial cable
This low-smoke PVC jacket is designed for the company's LMR-FR and
LMR-LLPL low-loss, flexible 50-ohm coaxial cables. It is designed for
in-building cable runs between an antenna and radio equipment, and is
off-white to blend in with decors.
Times Microwave Systems
Circle 197
Nonmetallic surface raceway
MediaTrak 8 is a two-channel, medium size, one-piece surface raceway
with a double latching cover. It is suitable for both communications
and electrical cabling runs simultaneously with a barrier separation.
It features fittings that have a 1.25-in. minimum bend radius.
Hubbell Premise Wiring
Circle 175
Cat. 6 cabling system
This Cat. 6 cabling system exceeds all TIA and ISO-proposed
performance requirements for Cat. 6/Class E cabling systems and
components. It supports unshielded twisted pair voice or data
applications — including Gigabit Ethernet. It supports 180°
and 90° cable termination.
Amp Netconnect
Circle 152
© 2008 Penton Media, Inc.
