Product News
Mar 1, 2003 12:00 PM, By EC&M Staff
Cordless drills
The Lok-Tor series of 14.4V and 18V cordless driver/drills and
hammer-drills delivers high torque and high speeds. The drills feature
an all-metal, single-sleeve ratcheting chuck with carbide jaws that
provides grip torque on the drill. They also produce speeds as high as
1,700 rpm in 2-speed gear cases.
Milwaukee Electric Tool Corp.
Circle 250
Electronic ballast
The ICN-4S54-90C-2LS is designed for the operation of as many as
four lamps, at any input voltage between 120V and 277V, 50/60 Hz. The
electronic ballast also operates 36/39W, 50W, and 55W long twin tube
lamps, as well as F58T8 lamps.
Advance Transformer Co.
Circle 251
Crimping/cutting tool
The J1005 is designed to crimp insulated and non-insulated 10 AWG to
20 AWG solderless terminals and connectors. The tool has markings to
identify the insulated or non-insulated crimping dies. It features a
dual-material handle design, measuring 9.75 in. in length. The
crimping/cutting tool also carries a lifetime warranty.
Klein Tools
Circle 252
freeproductinfo.net/ecm
Vinyl cloth labels
The B498 vinyl cloth labels use a pressure-sensitive, rubber-based
adhesive to allow clean removal and repositioning. The labels have a
formulated topcoat for thermal transfer printing and are designed for
use in general industrial, datacom, and electrical applications. They
allow end-users to identify the wires during assembly, both before and
after termination.
Brady, Inc.
Circle 253
Cable ties
Low-Profile cable ties eliminate cuts and abrasions to wires,
cables, hoses, products, and users. The 7.5-in. ties provide strength
while allowing the head to flex around the contour of the bundled wires
or tubing. They have a tensile strength of 50 lbs and come in bags of
100 and 1,000. The ties can be used in OEM, HVAC, and telecom
projects.
3M
Circle 254
Plate and box supports
Uni-Mount mounting plate and box supports fit 4-in. square boxes and
eliminate the need to stock and assemble multiple parts. The plate and
box supports are designed for use with metal or wood studs. UL Listed
and CSA certified, they're available as a single or two-device cover
and come in .5-in., .625-in. and .75-in. raised covers.
Cooper Crouse-Hinds
Circle 255
Duct rodders
These duct rodders are constructed of fiberglass strands with
thermosetting gel and proprietary strengthening agents. A UV-stabilized
safety-yellow polypropylene coating offers protection against water and
extreme temperature conditions. The rodders are mounted on lightweight
tubular steel carriers protected from corrosion by a black-oxide
finish. They're available in .25-in., .375-in., and .5-in. diameters in
lengths from 100 ft to 1,000 ft.
General Machine Products Co.
Circle 256
Crimping dies
These 12-ton and 6-ton crimping dies are available in four different
kits, allowing distributors a single source for crimping dies. They
save the time required to inventory multiple die sets. The UL and cUL
classified dies are designed for use on copper and aluminum lugs and
splices. The 12-ton kits contain 15 dies for color-coded aluminum or
copper connectors from 6 AWG through 750Kcmil, and the 6-ton kits
contain 15 connectors from 8 AWG through 350Kcmil.
Greenlee Textron
Circle 257
Power analyzer
The 806 power analyzer offers four test programs, including the
standard energy and harmonics program and optional disturbances
program. It provides single- and 3-phase measurements with
auto-configuration to standard electrical systems, along with true rms
readings. Other features include 1MB of internal memory, optional FIFO
memory, and auto detect clamps.
IDEAL Industries, Inc.
Circle 200
Web reporting tool
The Total Web Solutions (TWS) Ethernet card and Web reporting tool
allows users to access and monitor real-time power data via the
Internet. It provides Web-based power meter information features from
online substation monitoring to system-wide energy management. It hosts
the data directly on the series power meter and includes a range of
features, including fully customized Web page development and instant
alarm e-mails direct from the meter.
Electro Industries/Gauge Tech
Circle 201
Integration software
The UniNet 2000 incorporates fire, security, access control, and
CCTV on a single network. This client-server technology allows
operators to integrate fire and security building systems into a
customized, graphics-oriented platform, creating a unified command
center for monitoring and controlling building safety systems. It
features a history manager that provides flexible access to stored
events using filters and configurable automatic history backups.
Notifier
Circle 202
Trip units
Micrologic trip units provide power metering and monitoring,
protective relaying, and the ability to communicate with an entire
electric distribution system. They offer basic circuit protection,
including LED trip indication and long-time, optional short-time, and
instantaneous protection adjustments. The ammeter version provides a
phase-loading bar graph, ground-fault protection, zone selective
interlocking, and communications interfaces.
Schneider Electric/Square D
Circle 203
Safety training program
The “Safe Behavior — No Regrets” CD-ROM teaches
workers to analyze everyday choices to ensure workplace safety. The
program covers principles of behavior awareness, the power of positive
reinforcement, the importance of interpersonal communication, and how
to make safety a part of everyday work practices.
Summit Training Source, Inc.
Circle 204
Battery system
The PowerSafe DDm battery system provides long service life for
applications that require large capacity valve-regulated batteries,
such as telecommunications, power generation and distribution, and
uninterruptible power supply (UPS) applications. The battery cells are
encased in protective steel shells that provide consistent compression.
The module design uses thermal management that allows airflow, and the
one-piece container construction helps improve leak resistance.
EnerSys, Inc.
Circle 201
Clamp meter test kit
The TK32 clamp meter test kit is designed for professionals who
install, troubleshoot, and repair electrical and HVAC equipment. The
kit includes an autoranging, true rms clamp-plus-multimeter that
measures AC/DC current to 600A with 0.1A resolution. It measures
voltage, resistance, capacitance, and temperature. The kit also
includes a set of 1,000V CAT III test leads, a type-K temperature
probe, and a carrying case with wrist strap.
Extech Instruments
Circle 205
Explosion-proof enclosures
These explosion-proof enclosures are available with bi-directional
bolt-on mounting lugs that allow either vertical or horizontal mounting
orientation. The ductile aluminum alloy lugs adapt to irregular
surfaces so the bolts can be tightened without damaging the enclosure.
Certifications include UL Standard 1203 and CSA Standard C22.2 No.
30.
Adalet
Circle 206
Generator set
The G3500 series natural-gas-fueled gen-sets are designed to deliver
electricity at low cost per kilowatt-hour in both island mode and grid
parallel operations. The gen-sets are driven by lean-burn gas
reciprocating engines in 12-, 16-, and 20-cylinder configurations,
operating at 1,500 rpm/50 Hz, 1,200 rpm/60 Hz, or 1,800 rpm/60 Hz, with
ratings as high as 2.1MW. They use an open combustion chamber design,
and their low-pressure fuel systems allow them to fit in a range of
distributed generation settings.
Caterpillar
Circle 207
Stainless steel motor
Premium stainless steel motors are designed to withstand corrosive
solutions containing lye, bleach, acids, alkalines, and surfactants.
Double-sealed bearings pre-lubricated with moisture-resistant,
high-temperature grease are used on both ends of the motor. They're
available with stock ratings from .5 hp to 10 hp and 1,750 rpm to 3,450
rpm, with selected ratings available in 1,140 rpm. The stock motors are
configured with NEMA C faces and mounting bases for universal
mounting.
Leeson
Circle 208
Safety signs
Trident safety signs are easy to mount and come with a 30-year
warranty. The three-color, 3-D engraved signs won't fade, crack, chip,
or peel, and will withstand the damaging effects of extreme
temperatures and other harmful weather conditions. They're available in
three standard sizes of 7 in.×11 in., 10 in.×14 in., and 14
in.×20 in., with a choice of hundreds of safety messages.
Almetek
Circle 209
Surveillance systems
The Quiet-Cool series security surveillance and monitoring console
is designed to meet the demands of today's technology with an active
thermal management system to keep equipment cool. It also has sound
isolation capabilities, including acoustic damping material on the
insides of side panels, gasketing on all doors, quiet-running fans,
baffled fan exhausts, and air intakes.
Middle Atlantic Products
Circle 210
Surge protector device
This line of Surgelogic surge protector devices (SPDs) provide
transient voltage surge suppression. The SPDs meet a range of peak
surge protection to 480kA. They're available in multiple formats and
meet a range of application needs, from commissioning to
retrofit.
Circle 150
Power management software
The upgraded Personal Solutions-Pac power management software offers
user-friendly features to SOHO and small businesses. The software can
operate in Windows ME/2000/XP hibernate mode, and when input power is
interrupted, it will automatically save all open files in process and
initiate hibernation. It also includes a screen that displays remaining
battery backup time available, letting the user know whether additional
devices can be safely plugged into the UPS without overloading the
system.
MGE UPS Systems
Circle 151
Surge protector
The Snap Lite is a quick-connect surge protector for 66-block
multiple-line systems. Its single-pair configuration and five service
voltage options (30V to 130V) addresses a variety of telecom, voice
data, and twisted-pair video applications on the same 66-block. An LED
light on the face of the unit goes out if the surge protector has
blown, simplifying troubleshooting. If the light is off, the protector
has performed its job and protected telecom equipment. The surge
protector features sneak-current protection and guards against both
over-amperage and over-voltage conditions. Able to survive thousands of
small surges, it allows a continuous current of 150mA and offers
tip-to-ground and ring-to-ground protection modes. The surge protector
measures 3.25 in.×1.6 in.×.38 in. and weighs 14g.
Ditek Corp.
Circle 152
Monitoring system
The I-Grid is an Internet-based, real-time distributed power quality
and reliability monitoring and notification system that uses low-cost
monitors. The system-wide grid monitoring effort helps improve customer
service by using monitors that are less than 10% of the cost of
existing monitors. Utility applications range in variety from
monitoring customer sites, substations, and feeders, to outage
reporting and enabling delivery of value-added services.
SoftSwitching Technologies
Circle 153
© 2008 Penton Media, Inc.
advertisement
