Product News
Uplights
Available with a natural bronze or brushed stainless steel finish, the Lightvault Series and Minivault Series of LED uplights feature low heat output and more than 50,000 hr of lamp life, according to the company. In addition, both models feature a tempered clear soda lime lens and a lens gasket made from one-piece molded silicone with U-channel. The 18W LED Lightvault is offered in spot or narrow flood distributions, while the 5W, 6W, or 15W Minivault Series is offered in spot, narrow flood, or wide flood.
Kim Lighting
Circle 250
Junction box
This 19-cubic-in. junction box is UL-listed and can accommodate multiple circuit applications. Made of high-impact compression-molded phenolic plastic, the corrosion-resistant junction box is suitable for wet locations. In addition, it is rated for use with circuit conductors up to 150°C.
Engineered Products
Circle 251
Hole saw stop
This T-Slot hole saw includes a stop feature that the company says allows users to control the cutting edge of the saw, allowing it to penetrate ⅛ in. from the cutting surface. In addition, the stops can be removed and transferred between hole saws for use on one to four stops.
Greenlee, a Textron Co.
Circle 252
freeproductinfo.net/ecm
Cable lock
Kwik Loc cable locks are used to suspend fluorescent and HID lighting equipment, cable trays, fan units, or seismic bracing (cable locks are to be used on static load applications only). Made of metal alloys and stainless steel, the products allow users to position the hangers vertically or at an angle to the suspended object. Available in four sizes with working loads up to 640 lb, they feature an easy-release pin that the company says allows for adjustment without the need for tools.
Rize Enterprises
Circle 253
Light sensor
The Square D Clipsal Light-Level Sensor measures ambient light levels and automatically issues on, off, or ramp commands over a C-Bus network. The wall-mounted, low-profile unit can control relays, dimmers, or remotely operated circuit breakers, changing their status according to preset ambient lighting levels. Featuring ranges between 5 footcandles and 150 footcandles, the sensor compensates for noise and rapid light intensity fluctuations by using filtering and hysteresis. In addition, it detects daylight levels and automatically adjusts the output level of electric lighting.
Schneider Electric
Circle 254
Acceptable Use Policy
what's wrong here?
May 10, 2012 12:44 PM
Apr 19, 2012 10:09 AM
Apr 5, 2012 2:27 PM
View all What's Wrong Here?
product spotlight
EV charger tester
May 25, 2012 8:26 AM
EV charger tester
Free Product Info
Recent Comments
More...
Social Media
More ways to stay informed...
follow us on twitter
Find us on Facebook
EC&M Whitepaper
Date: Wednesday, May 30, 2012
Time: 2:00pm ET
Grounding Versus Bonding
Now Available On-Demand
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
industry links
industry links
rss icon
rss
Browse Back Issues
Browse Back Issues
