New Products
Jan 1, 2001 12:00 PM, By EC&M Staff
Thermal transfer labels
PAN-CODE thermal transfer labels suit a variety of applications,
including wire marking, bar-code labeling, and shipment tracking. Label
types include self-laminating thermal transfer labels, specialized
blank thermal transfer labels, heat-shrink labels, and thermal transfer
ribbons.
Panduit
Stick lubricant
The new Mini Rotabroach Stick Lubricant is a specially formulated
lubricant you can use with the company's lines of Rotabroach annular
cutting tools. Available in the new 1.68-oz size, it provides clean
tool protection (no coolant spills or dripping). The unit is ideal for
use when drilling overhead, when the drill is inverted or in a
horizontal plane where liquid coolants would fail to provide adequate
protection at the cutting edges. The product is appropriate for use
with ferrous or nonferrous metals.
Hougen
Fiber optic installation kit
Housed in a mechanic's bag, the Basic Fiber Optic Kit is a package of
fiber optic installation tools that includes: a 1002 fiber optic scope
for viewing fiber before and after cleaving; a pen-sized
fiber-continuity tester; the IDEAL Mini-Lite Optical Fiber Stripper; a
Kevlar cutter; a carbide fiber optic scribe; a fixture for polishing
optical fiber ST- and SC-type connectors; and additional space.
Ideal Industries
Surface-mount transformer modules
This two-member (S558-5999-T5 and S558-5999-U5) family of surface-mount
magnetic 10/100Base-T transformer modules has a temperature range of
140 to `85 C, and conforms to IEEE 802.3u standards.
Bel Fuse
Optical fiber raceway
Plenum-Gard is a UL-listed nonmetallic, corrugated, flexible conduit
for use in plenum/riser and general-purpose applications. It's made
with Elf-Atochem's KYNAR material for low-smoke, low-flame propagation
properties and is available in 3/4-in. through 2-in. sizes.
Carlon
UHF male crimp connector
The EZ-400-UM non-solder "EZ" install Type-UHF male connector
eliminates the need to solder the center conductor and braid. The
center conductor slides into a silver-plated spring finger contact pin,
and the outer braid is attached with a crimp-style attachment ring
using standard .429-in. hex dies.
Times Microwave Systems
Wire management products
OmniLink now provides new opportunities for single-source purchasing.
It features a comprehensive line of power, voice, data, and video
products that provides installation benefits for electrical contractors
and installers.
Thomas & Betts
Fiber optic switch/converter
Using the Model 4185 fiber optic switch/converter, you can access two
separate fiber optic 100Base-FX ports from a 100Base-TX Fast Ethernet
port (COMMON port).
Electro Standards Laboratories
Large-capacity poke-through
The Walker RC4 Series poke-through is an open-space wire and cable
management system. It provides for two dual-circuit 20A single duplex
receptacles, wired on individual circuits with separate neutral and
ground wires. It supports four multimedia datacom connectors.
The Wiremold Co.
Flexible electrical conduits
Available in three types, these flexible electrical conduits offer
electromagnetic and radio-frequency interference shielding. By
permitting traditional wiring solutions in shielding applications,
these liquidtight conduits provide an alternative to specialized
shielded cable assemblies.
Electri-Flex
PC-based OTDR
This optical time domain reflectometer (OTDR) module works with any
Windows PC to offer full OTDR functionality. It's portable for field
use, versatile for the lab, and perfect for teaching - its display can
be projected from the PC or viewed on a large-screen monitor.
fotec
Media system
The Decora Media System converts stereo audio and baseband video
signals for home theater and distributed audio/video to Cat. 5
unshielded twisted pair. It incorporates active electronics, and its
circuitry is capable of streaming analog audio and video signals over
distances of up to 300 m - without audio distortion or noticeable video
artifacts.
Leviton
Fiber test installer packages
Two new fiber test installer packages, the FTI Basic and FTI Pro,
simplify fiber testing by giving technicians all the test and
inspection tools they need in one compact kit. Both packages include
easy-to-use fiber testers that test multimode fiber at 850 nm and 1300
nm wavelengths.
Fluke Networks
Surge and lightning protector for radio lines
The COAXTRAB CN-LAMBDA/4 surge and lightning protector uses a 1/4-wave
filter design to eliminate surge voltages from radio antenna lines.
Designed to operate on 2 GHz 515%, this unit is ideal for protecting
mobile-phone and other cellular base stations from lightning-induced
surges that enter through coaxial lines.
Phoenix Contact
Power addition kits
Power Addition Kits are for use with Panduit PAN-POLE power and
communications poles. These kits are UL-listed for the field
installation of up to three additional duplex outlets on each pole.
Outlets may be added to the existing PAN-POLE factory-wired circuit, or
an additional circuit may be added to the pole for a total of two. The
kits are available in two versions, with or without a 20A rectangular
outlet and two outlet mounting screws. Both versions include an outlet
mounting bracket with mounting screw and a snap-in faceplate.
Panduit
Solid-state relays
The HETP series of thermally managed AC solid-state relays delivers
3-phase SCR output to 100A per phase, 1600V. They provide control of
high amounts of power in 3-phase applications, and the optical
isolation feature protects circuit control elements from transients in
the load. Benefits include standard control status LED, choice of AC or
DC inputs, and constant current input.
Teledyne Relays
Severe-duty motors
The new W21 motor line offers the high performance of a severe duty
motor at a standard motor price. It's interchangeable with the
company's current standard motor and has an improved fan cover to
reduce noise levels. Upgraded insulation (NMN, Nomex Mylar Nomex, for
frames 364T up to 586/7) now meets inverter-duty application
requirements for 460V and below.
WEG Electric Motors
Lock-out relays
The Series 24 Lock-Out Relays (LORs) with Smart Nameplates feature LEDs
that continuously display trip coil continuity and provide a clear
warning against closing into a fault. In operation, the LOR trip coil
continuously monitors continuity. In the reset position, an LED glows
green, indicating the coil circuitry is intact and the LOR is ready to
respond to a trip signal. Should the LOR trip coil fail, the green LED
extinguishes and a built-in contact closes, sending notification signal
to SCADA. If a fault is detected, the LOR trips. A red LED then lights
and functions as a trip signal monitor.
Electro switch
Progammable logic controller
The VersaMax SE programmable logic controller accessory enables
Ethernet connection via the serial port on a micro or nano controller.
It allows users to solicit and send information, upload/download
programs, and monitor and control devices over the Ethernet. Measuring
2.4 in.23.7 in.21.4 in., it features DIN-rail mounting, allowing users
to install the product onto a DIN-rail rack and attach the serial
interface of the device to the controller.
GE Fanuc Automation
Cutting and stripping tools
Greenlee Pro Strippers are marked for solid and stranded wire - which
means you don't need to carry two tools. The blades are longer than on
competitive tools, so they easily cut NM cable in one stroke. They are
also curved, which reduces cutting force by 25%. Equipped with wire
looping holes, they have a locking tab to protect the blades during
storage in a tool pouch.
Greenlee Textron
Multispeed motor
The Cooling Tower multispeed motor is designed for applications in
extreme moisture environments. The Design B, 60 Hz, Class F motor
operates in a 407C ambient temperature and 1.15 service factor.
Additional features include type "YA" lead lugs, lip seals on both
brackets, T-drains, and stainless steel nameplates. It's also equipped
with cast iron bearing caps for the double-shielded ball bearings,
alemite grease fittings, and an epoxy-coated rotor and stator.
Rockwell Automation
Sign luminaire
The Sign-Vue II luminaire provides sign legibility for highway signs
and building facades. Hot spots and dark spots are eliminated by the
prismatic glass refractor, which uniformly disperses the maximum amount
of light across the entire sign face with minimal energy consumption.
Its shallow profile offers a clutter-free look that doesn't obstruct
the message. It meets UL 1572 rain test requirements.
Holophane
Terminal enclosures
The TSC4 series of increased safety screw cover terminal enclosures
provide explosion protection by utilizing additional security against
the possibility of excessive temperature and of the occurrence of arcs
and sparks. This is accomplished through additional assurances in
matters of electrical clearances and the security of electrical
connections.
DEMKO
Socket sets
The tools in this safety socket set are double-insulated and
manufactured to ASTMF-1505.94 standard for work on energized circuits
with voltages up to 1000VAC (1500VDC). When the outer orange insulation
layer has worn, the lower yellow layer shows through, serving as an
early warning to take the tool out of service. The sets are available
in standard and deepwall styles, in 12-point or 6-point, in 1/4-in.
through 1/2-in. square drives. Metric sizes are also available. The
sets include extension bars and a cloth tool roll for protective
storage.
Cementex Products
Strut nut
The new CADDY SLICK strut nut provides fast, universal attachment of
threaded rod and hardware to standard strut profiles. It replaces
difficult-to-handle spring nuts and can reduce installation time by up
to 70%. The unit's design toggles into place and eliminates the need
for a washer. An integrated plastic strip provides tension to grip the
strut, yet allows for easy repositioning or removal.
ERICO
Spring steel fasteners
Twelve product series and more than 70 catalog numbers have been added
to this company's Steel City Spring Steel Fasteners product line. They
include the SC6 Armored Cable to Stud Clip, AC/BX/MC cable hangers, the
SGA Series Electrical Box to Stud Adjustable Bar Bracket, and the VT
Series Strap Tie Cat. 5 Cable Support.
Thomas & Betts
Reciprocating blade
The new King-Cut reciprocating blade is the newest addition to the
company's line of Yellow Saw Blades. Unlike standard .035-in. or
.050-in. blades, the unit is .063 in. thick, allowing it to easily cut
through virtually any difficult combination of building materials. The
blade features a thick, durable, high-speed steel cutting edge with
heat-treated teeth - set at an aggressive variable pitch and welded to
a tough 1-in. back.
The L.S. Starrett Co.
Temporary lighting system
This High-Intensity Discharge (HID) temporary lighting system is
designed for indoor construction sites where mounting heights exceed 15
ft. Features include a lightweight die-cast aluminum ballast housing
with easy-grip handles, sturdy lamp cage, and coated lamp with a 250W
or 400W metal halide or high-pressure sodium lamp.
Crescent/Stonco Lighting
Tool carrier
The Pocket Pal heavy-duty tool carrier fits in your back pocket and has
a pouch that hangs over the outside pocket to double the tool-toting
capacity. It allows you to carry up to seven tools without stretching
or ripping pants, yet measures 6 1/2 in. 24 1/2 in.
Ideal Industries
Cable reel
The Hannay NSCR700 cable reel features a compact design with a sturdy,
narrow frame for use with live electrical cable. It can be mounted in
confined spaces and is ideal for use with power tools, lights,
machinery, and generators. A heavy-duty spring motor provides
self-contained rewind power, with a non-sparking ratchet assembly that
locks the reel when the desired length of cable is payed out. The unit
houses a standard 45A, 3-conductor, 600V collector assembly with No. 8
gauge wiring.
Hannay Reels
Camouflage tool bags
These tool bags feature the Realtree Advantage camouflage pattern line
that comes in 14-in., 18-in., and 24-in. tool bags as well as a 12
1/2-in. zipper tool bag. They have resistance to abrasions, punctures,
and tearing. Features include a rugged steel frame mouth with hinge for
easy access, and a retaining strap with buckles for secure
closure.
Klein Tools
Hammer-drill kit
The new 1/2-in. Hammer-Drill Kit, model 5378-21 combines a compact
lightweight design with a powerful 7.5A motor. This tool drills up to
5/8-in. holes in concrete, masonry, brick, or block. A dual-torque
gearbox provides high-speed drilling (0 rpm to 3250 rpm) in high-speed
range for smaller bits, and plenty of torque for larger bits in the
low-speed range setting (0 rpm to 1350 rpm).
Milwaukee Electric Tool
Pull tape
Bull-Line pull-tape products expedite cable installation. They are
available in polyester or aramid-fiber constructions, and in multiple
reel sizes or factory pre-installed into conduit. The tapes are printed
with sequential footage or metric markings for accurate in-field
measurements. Corrosion-resistant Bull-Line Woven Tone-Tape features a
tracer wire for signal locating.
ARNCO
© 2008 Penton Media, Inc.
