Product Spotlight
Dec 1, 2003 12:00 PM, By EC&M Staff
Visual fault finder
The VFF5 assists users with finding breaks, faulty splices, crimps,
and poor components or connections in fiber cabling. This hand-held,
battery-powered fault finder is equipped with a red light that can
travel through 3 mi of jacketed or bare fiber optic cabling. The 670 nm
laser diode allows for operation in continuous or modulated mode. It
features a rugged, metal housing and is fitted with a standard adapter.
A carrying case, lens cap, two AA batteries, lanyard, and instruction
sheet are also included.
Ideal Industries
Circle 303
Connector inspector
The CI-1000 Connector Inspector provides 400X magnification for the
inspection of connectors in the adapter. The inspector is available in
three versions: LCD, USB and handset, and each version includes an
integrated battery pack and a 3.5-in. LCD monitor for field
inspection.
Lightel Technologies
Circle 301
Fault finder
Using time domain reflectometry, the TDR900 fault-finding instrument
measures power, telephony, CATV and LAN cable lengths, and the distance
to an open or short. It contains an internal library of 39 standard
cable types and a range of six automatic output impedance controls from
25 ohms to 150 ohms. The measuring range spans from 15 ft to 10,000 ft
with a minimum resolution of 20 in.
Megger
Circle 304
Optical multitester
The model 500 optical testing platform features test and measurement
options like an optical time domain reflectometer (OTDR), connector
inspection, chromatic and polarized mode dispersion, optical spectral
analysis, and Gigabit Ethernet system testing. The Windows-based
multitester is available in three sizes, depending on the number of
field-installable models used. It's also equipped with a light source
and power meter for complete end-to-end loss testing.
Corning Cable Systems
Circle 302
Test kit
The MicroScanner Pro VDV kit contains information and tools for the
verification of voice, data communications, and video cable
installations. The kit includes a MicroScanner Pro cable verification
tester, MicroProbe toner probe, remote wiremap adapter, office/room ID
set, and adapters for testing coaxial cabling and two-conductor wire.
Also included is the “Business in a Box” CD-ROM, which
features information on the basics of residential VDV applications and
cable types, cabling preparation, termination, installation standards
and practices, and proper testing methods.
Fluke Networks
Circle 300
© 2008 Penton Media, Inc.
