ECM Buyers' Guide
Focus on Motors & Motor Controllers
Motor control center
The Tiastar Smart motor control center (MCC) product line has been expanded to include a series of gateway solutions that transition the Profibus-DP network inside the Smart MCC to the customer-desired control network. The gateway solutions are factory installed and programmed in a 12-in. MCC bucket. Additionally, the MCC delivers detailed diagnostics and control by communicating with the started units via PLC/DCS.
Siemens Energy & Automation
Circle 300
Motor disconnect switch
The Square D MD50 motor disconnect switch cuts power to a motor without affecting the main circuit. According to the company, IEC 60309-compliant technology makes it almost impossible to plug in a power receptacle having different voltage and ampere ratings, while a mechanical interlock forces an operator to insert a plug before power can be turned on and to turn power off before the plug can be removed. Prewired for installation, the product also features a watertight ground hub, two grounding blocks, moveable mounting feet, and internal mounting tubes.
Schneider Electric
Circle 301
Gearmotor
The Dodge Quantis Gold combines Dodge Quantis ILH and RHB C-face gearmotors with Baldor•Reliance Super-E premium efficient motors. The Quantis ILH and RHB reducers feature a NEMA clamp-collar design, foot-mounted housing configurations, standard inch output shafts, nitrile input and output lip seals, A1 mounting, and Mobilegear 600X XP 220 oil. In addition, the RHB unit offers flange-mounted housing configurations and tapered hollow bores with twin-tapered bushings.
Baldor Electric
Circle 302
Control regimen
OptimalFlux is a control regimen for standard totally enclosed fan-cooled (TEFC) induction motors. According to the company, the regimen enables a standard TEFC motor to operate at a cooler temperature across its entire speed range. Available as an option with any of the company's standard CFW09 variable-frequency drives, it can also be used with the company's standard NHE or NPE motors rated from 1 hp to 300 hp.
WEG Electric Motors
Circle 303
Acceptable Use Policy
what's wrong here?
Feb 2, 2012 7:54 PM
Jan 19, 2012 4:06 PM
Jan 5, 2012 11:53 AM
View all What's Wrong Here?
product spotlight
Labeling tool
Feb 10, 2012 7:58 AM
Labeling tool
Free Product Info
Recent Comments
More...
Social Media
More ways to stay informed...
follow us on twitter
Find us on Facebook
Arlington CP9000
Arlington Gangable Boxes
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
industry links
industry links
rss icon
rss
Browse Back Issues
Browse Back Issues
