Product Spotlight
Sep 1, 2002 12:00 PM, By EC&M Staff
Rough terrain scissor lift
The model 3394RT has a 33-ft platform height and 2,250-lb platform
capacity. The load management system for the fuel-injected engine
prevents it from bogging down in rough terrain conditions. The unit has
a dual pump hydraulic drive and 3-speed selectable drive controls, and
has been job tested at 45% grade.
JLG Industries
Circle 345
GFCI cord
This in-line GFCI-protected triple tap complies with OSHA
regulations for GFCI use. It's rated 125V/15A, UL/CSA-approved for
indoor or outdoor use, and rainproof rated. The 12/3 SJTW cord has an
overall length of 3 ft, and the unit has an LED power light.
RDW Group
Circle 342
Truck caps
The Deluxe Commercial Unit (DCU) truck caps are made of rugged,
fully welded aluminum frame construction. They are available with more
than 200 options, including a variety of door and window
configurations, colors, toolboxes, custom ladder racks, interior fabric
liners, side panels, and overall cap heights. All DCUs feature Strattec
lock cylinders in folding T-handles on all doors for added security, as
well as Suspa gas props on all doors.
A.R.E.
Circle 346
Metal cutting circular saw
The model 6320 18V, 6.5-in. cordless circular saw has a 3,200-rpm
motor for fast cutting. It cuts to a depth of 2.125-in. in one pass.
The saw has aluminum upper and lower guarding and a durable
nickel-plated steel shoe. The large lower blade guard lever is easy to
access.
Milwaukee Electric Tool
Circle 341
Ratcheting crimping tool
Equipped with four color-coded die grooves, the YIMR full-cycle
ratchet will accommodate a range of #8 to #1 Cu lugs and splices, and
the related copper C-Tap connectors. The color-coded die wheel rotates
matching die to a color-coded connector, embossing the completed
connection.
FCI Burndy
Circle 340
Torpedo level
The 930-9 is a 9-in. level that features a rare earth magnetic base
that is five times stronger than traditional strip magnets. The base
firmly holds the level to iron and steel surfaces, freeing the user's
hands for other jobs. The vials are framed with E-Z See,
glow-in-the-dark material for easy, accurate viewing in dimly lit
areas. No batteries are required.
Klein Tools
Circle 344
© 2008 Penton Media, Inc.
