ECM Buyers' Guide
Product Spotlight
Focus on Boxes and Enclosures
Corrosion-resistant enclosures
The Cardmaster 3 enclosure family is designed for instrumentation packaging such as measurement, monitoring, and process control equipment. Available in corrosion-resistant polycarbonate (PC) or ABS plastic, these enclosures have a maximum NEMA 4X rating and an IP65 rating. Offered in 13 different PC models, which are available UL listed, and 13 ABS models, the enclosures feature two separate compartments — one for circuit boards and sensors and another for terminals and wiring.
Fibox Enclosures
Circle 300
Industrial panelboard
The ALPN is a distribution panelboard designed to centrally control branch circuits used in lighting, heating, motors, and other industrial equipment. The panelboard is UL listed as explosionproof, is dust-ignition proof, and is rated watertight (NEMA 4X). Designed to meet NEC requirements for Class I, Div. 1 and 2 hazardous locations, the unit features a copper-free aluminum body, standard breaker operators, copper bus bars, Quad-Lead stainless steel cover bolts, optional 1-, 2-, or 3-pole breakers, and Cutler Hammer interiors.
Appleton
Circle 301
Die-cast box
This company's newest NEMA 4X- and IP65-rated box comes with a hinged cover for easy access to components. Made of aluminum alloy die-cast, the box comes with external mounting brackets for mounting on a wall or panel without having to remove the gasketed cover. It can be customized to meet user specifications and is available in two sizes: 3.95 in. × 3.04 in. × 1.98 in. and 4.54 in. × 3.92 in. × 2.23 in.
Bud Industries
Circle 302
Circuit breaker enclosures
Designed for Square D's H- and J-frame PowerPact molded-case circuit breakers, these enclosures are available in indoor, outdoor, flush- and surface-mounted models. The enclosure line offers five models, including a NEMA Type 12-rated gasketed, dust-tight version and a stainless steel NEMA Type 4 water-resistant and Type 4X corrosion-resistant model. The other enclosures are available for NEMA Type 1 flush- and surface-mounted indoor applications and NEMA Type 3R outdoor applications.
Schneider Electric
Circle 303
VRLA battery cabinet
This cabinet system is designed for the company's DataSafe HX range of valve-regulated lead-acid (VRLA) batteries. The cabinets are UL 1778 listed and approved for UBC seismic zone 4 installations. They are factory pre-wired and come with hinged front doors and removable rear panels, as well as several knockout locations and dual DC-rated fuses. The cabinets are available in a wide range of sizes with a number of customized options, including circuit breakers and castors.
EnerSys
Circle 304
Acceptable Use Policy
what's wrong here?
Feb 2, 2012 7:54 PM
Jan 19, 2012 4:06 PM
Jan 5, 2012 11:53 AM
View all What's Wrong Here?
product spotlight
Labeling tool
Feb 10, 2012 7:58 AM
Labeling tool
Free Product Info
Recent Comments
More...
Social Media
More ways to stay informed...
follow us on twitter
Find us on Facebook
Arlington CP9000
Arlington Gangable Boxes
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
industry links
industry links
rss icon
rss
Browse Back Issues
Browse Back Issues
