ECM Buyers' Guide
Low-voltage cable tester
Using time domain reflectometry, the TRD900 auto-ranging, fault-finding instrument can measure power, telephony, CATV and LAN cable lengths, and find the distance to an open or short. The instrument features an internal library of 39 standard cable types, and it functions with any cable consisting of at least two insulated metallic elements, one of which can be the sheath or shield of the cable. It has automatic output impedance control from 25 ohms to 150 ohms and a measurement range of 15 ft to 10,000 ft with a minimum resolution of 20 in.
Megger
For more information, visit http://www.megger.com.
Power distribution unit
The Power Commander vertical power distribution unit (PDU) provides 30A of power. It’s designed for communication racks, cabinets, and enclosures, and it features 24 or 36 simplex receptacles, dual circuits, easy-access breakers. It also includes a built-in T-slot to accommodate mounting accessories. It’s cUL-listed and meets UL60950-1 first edition and ITE standards.
The Wiremold Co.
For more information, visit http://www.wiremold.com.
Tool Belt
The Build-Your-Own-Bag system allows users to customize their own tool belt using several interchangeable components. The system is built upon a padded weight lifter belt made of heavy-duty nylon and outfitted with eight quick clips to add bags and accessories. Two types of bags are available for customization. The DS-970B bag consists of three inner compartments, four outer compartments, and three quick clips. The DS-911B bag contains four inner compartments, eight outer compartments, a “T” chain for tape rolls, and one quick clip. Users can also choose from a variety of accessories and pouches to further customize their belt like a hammer loop, tape clip, drill holster with bit pocket, and three sizes of pouches.
Daman Tools
For more information, visit http://www.damantools.com.
GPR system
The Interragator EZ GPR system uses electromagnetic waves to locate buried utilities. The system’s 2-parameter input adjusts the depth of investigation and soil type values, and a depth calibration routine automatically adjusts system settings. An on-demand backup cursor gives immediate and accurate location of buried utilities, while a high-frequency, 400-MHz antenna transmits and receives pulses during subsurface surveys. The antenna allows the system to detect utilities as small as 0.80 in. at depths of 18 in. The system can detect larger utilities down to 20 ft, depending on soil condition. It features a real-time display that’s daylight readable, and users can transfer data to an external computer.
Vermeer
For more information, visit http://www.vermeer.com.
Power quality analyzer
The WM3-96 power quality analyzer measures and controls several power quality parameters like TRMS measurement of THD, harmonic analysis to the 50th harmonic, voltage, current, and demand. The analyzer includes a 32-bit microprocessor encased in a 96 mm x 96 mm housing and displays measurements on a LCD. It can also use Modbus-RTU protocol for monitoring as many as 255 individual instruments when using Wattsoft3 software.
Carlo Gavazzi
For more information, visit https://www.gavazzionline.com/usaenergymn.htm.
product of the week
Fuel Cell
October 6, 2008 9:51 AM
American Power Conversion Fuel Cell
Recent Comments
www.createyourcountdown.com
I-Gard
Arlington Indoor InBox
Easy install makes Indoor InBox preferred for power & low voltage applications. Furniture and appliances stay close to the wall!...
Listen
Listen
Sponsored By:
On-Demand Webinar
- Sponsored by I-Gard
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
rss icon
rss
Browse Back Issues
Browse Back Issues
