ECM Buyers' Guide
September 2004 Products of the Week
Sep 7, 2004 10:41 AM
Certification tester
Designed for testing cables in home and small business installations, the NT900 Validator certification tester is equipped with Plan-Um software, which allows a user to layout a floor plan, denote where each cable drop will be installed, test and certify the system, document the cable job, print out reports, and archive jobs for future reference. The tester can also test coax, telephone, security/alarm, and audio lines for opens, faults, and conditions by using TDR technology and automatic test capabilities and upload the results to a PC or laptop. It features a 4-in. LCD, rechargeable Lithium-Ion batteries, a flash memory card, a remote, patch cables and adapters, two adapter power chargers, and a hard-sided soft zipper case.
Test-Um
For more information, visit www.test-um.com.
Nonmetallic pin-and-sleeve connectors
Designed for power distribution in exposition center ceiling drops, wall mounts, floor boxes, and portable panel-boards, these nonmetallic pin-and-sleeve connectors have a nonconductive exterior for enhanced safety. The connectors feature brass alloy sockets and recessed pins to help with conductivity, and an extended ground socket ensures a reliable connection. They’re available for 40A and 60A applications and accept flat and round cable.
Woodhead
For more information, visit www.woodhead.com.
Voltage safety detector
Designed to detect voltage 2.5kV and higher, the 44SVD personal voltage detector can detect 44kV from as far as 30 ft. As the detector is moved closer to the voltage-carrying conductor, its AC sensor plate picks up the radiated electric field, which is processed by the detector’s internal circuitry. Once the processed signal is above the threshold, it triggers the input of an integrated circuit, which turns on both a buzzer and LED. It comes with a pocket-sized case with a built-in clip.
AEMC
For more information, visit www.aemc.com.
Generator self-test verifier
Designed to evaluate and report the results of backup electrical generators, the Generator Self-Test Verifier checks that a generator has started, that its voltage is within a ±10% tolerance window, and that it has continued to operate for a minimum of two minutes. Mounted to the transfer switch, the device can monitor all possible voltages and phase configurations and requires 120VAC power. In the event of a test failure, it sounds an alarm and either closes a set of contacts or directly reports the failure to a central monitoring agency via telephone line or wireless connection when used with an optional reporting module.
Transtar Products
For more information, visit www.generatorverifier.com.
product of the week
Fuel Cell
October 6, 2008 9:51 AM
American Power Conversion Fuel Cell
Recent Comments
www.createyourcountdown.com
I-Gard
Arlington Indoor InBox
Easy install makes Indoor InBox preferred for power & low voltage applications. Furniture and appliances stay close to the wall!...
Listen
Listen
Sponsored By:
On-Demand Webinar
- Sponsored by I-Gard
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
rss icon
rss
Browse Back Issues
Browse Back Issues
