Flexilok nylon conduit fittings are designed for use with coarse and/or fine-pitch conduit or tubing. Featuring a one-piece fit with no threading of the conduit or tubing required, the fitting are halogen-, sulphur-, and phosphorous-free as well as UV-, salt water-, weak acid-, gasoline-, alcohol-, oil-, grease-, and solvent-resistant. IP-66-rated, they are available in PG and metric hubs and feature a temperature range of -58°F (-50°C) to 275°F (135°C).
Heyco
For more information, visit www.heyco.com
