Bodine ELI-S-20 Emergency Lighting Micro Inverter
Jan. 26, 2011
The Bodine ELI-S-20 Emergency Lighting Micro Inverter is unit equipment that transforms LED and fluorescent fixtures up to 20W into code-compliant emergency lighting
The Bodine ELI-S-20 Emergency Lighting Micro Inverter is unit equipment that transforms LED and fluorescent fixtures up to 20W into code-compliant emergency lighting. ELI-S-20 is ideal for screw-base lamps and features an LED-friendly sinusoidal waveform. The micro inverter supplies 90 min. of illumination, powers designated fixtures at full brightness and is UL Listed.
Philips Emergency Lighting
Chapter 9 of the NEC — Part 5
