Baldor Super-E Motor
Jan. 26, 2011
The Baldor Super-E Motor with AEGIS Shaft Grounding Ring incorporates an internally mounted shaft grounding ring which can prevent bearing damage caused by drive-induced currents
The Baldor Super-E Motor with AEGIS Shaft Grounding Ring incorporates an internally mounted shaft grounding ring which can prevent bearing damage caused by drive-induced currents. This new line of motors is stocked from 1-50 Hp in TEFC and ODP enclosures. Applications include heating, ventilating and air conditioning blower and fan motors, pump motors, and other general purpose applications using an adjustable speed drive.
Baldor
Baldor
Strut Comparison Chart
