These grounding transformers are suitable for use at large multi-turbine wind farms where the substation transformer frequently provides the sole ground source for the distribution system. Featuring a primary voltage rating of 400V to 46kV, the transformers include secondary spade connectors when required, primary clamp-type eyebolt connectors, combination drain and sampler (750kVA and above), pressure test and upper filter press connection, and a NEMA two hole ground pad
Pacific Crest Transformers
For more information, contact www.pacificcresttrans.com.
