Table box
Cable retractors accommodate up to 5 ft of Cat. 6, HDMI, VGA, or 3.5-mm audio cable Cable grommet kit accommodates up to eight pull-out connections Two 15A receptacles in the top compartment and one 15A receptacle on the underside
Feb. 28, 2014
The Wiremold InteGreat A/V table box provides power, A/V, and communication to the work surface point of use. Integral cable retractors accommodate up to 5 ft of Cat. 6, HDMI, VGA, or 3.5-mm audio cable and latch onto the side of the box. Supplied with a cable grommet kit that can accommodate up to eight pull-out connections or accept up to five Wiremold AVIP or Extron MAAP installed connectors, the box includes two 15A receptacles in the top compartment and one 15A receptacle on the underside. In addition, the activation surface can be adjusted from 1 in. to 4 in. to allow the cover to close even when using large connectors. Other features include: a brushed aluminum, anodized cover with beveled edges and soft-touch handle; black and silver finishes; a pocket door that fully recesses into the table box when open; and a finishing plate that hides hardware on the activation surface and allows for labeling of the device plates.
Legrand
For more information, visit www.legrand.us.
