Programmed start T8 ballasts
ProLume programmed start T8 ballasts heat the lamp cathodes prior to applying the starting voltage, resulting in a 25% longer lamp life.
Designed for use in buildings with occupancy or daylight sensors and in applications with frequen
t on/off switching, ProLume programmed start T8 ballasts heat the lamp cathodes prior to applying the starting voltage. According to the company, the average rated life for T8 lamps is typically 25% longer when operated together with a ProLume programmed start T8 ballasts compared to an instant start system. In addition, the products operate in parallel mode and are CEE listed.
Halco Lighting Technologies
For more information, visit www.halcolighting.com.
