Low-voltage wire
Designed for landscape and residential interior applications, Q-Wire low-voltage wire features extra jacketing and an
oval-shaped design, allowing for a compression fitting that makes a completely water-tight connection. Rated for 90°C, the stranded copper conductors are tin-coated to prevent any potential for oxidation. The inner jacketing is color-coded, one blue the other yellow, to match up with the terminal blocks on the company’s direct burial series. In addition to being listed as UF-B 90C, the product is also listed as stranded Romex.
Q-Tran
For more information, visit www.q-tran.com.
