LinearX Compression Hip Kit
Includes tools needed to strip, cut, and terminate coaxial cables Contains the company's LinearX compression tool Works with many manufacturers’ 21-mm F connectors
June 9, 2014
The LinearX Compression Hip Kit includes the tools needed to strip, cut, and terminate coaxial cables. The kit contains the company's LinearX compression tool, the PrepPRO coaxial stripper for RG59 through 6Quad, and the Data-T Cutter, all housed in a hip pouch. When used with the company’s F or RCA connector, the tools create a 360° permanent termination that will not come loose. In addition, the tools work with many manufacturers’ 21-mm F connectors.
Ideal Industries
For more information, visit www.idealindustries.com.
