LED retrofit downlights
Suitable for indoor and outdoor lighting applications, MaxLED LED downlight retrofits feature an E26 medium screw base and a universal 120V to 277V power supply.
The MaxLED line now includes LED downlight retrofits for indoor and outdoor
lighting applications. Offered in a white-painted architectural finish, the damp- and wet-listed LED modules with integral trim feature an E26 medium screw base to replace incandescent lamps in most new construction and remodel recessed downlights. A GU24 adapter is available for CFL downlight housings currently using a GU24 lamp. Additionally, the downlights feature a universal 120V to 277V power supply. The RR40930W model is designed for use with most 4-in. recessed downlights and can be used to replace a 50W equivalent halogen light source. The RR61430W model is Energy Star-rated at 3,000K, and is also available in a 5,000K color temperature. This version uses torsion springs designed to easily retrofit into most 5-in. and 6-in. housings, and can be used to replace a 75W equivalent halogen light source.
Maxlite
For more information, visit www.maxlite.com.
