Ecmweb 7498 Kirk Key Typeff Interlock Safeguard
Interlock safeguard
June 19, 2015
Brass lock housing and cylinder ¾-in travel with ½-in. stainless steel lock bolt 7-pin tumbler key design
The Type FF reduced-size mechanical bolt interlock for smaller stature breakers helps ensure workers follow a predetermined sequence of operation to safely access electrical switchgear. Manufactured with a brass lock housing and cylinder, the device features a ¾-in travel with a smaller diameter ½-in. stainless steel lock bolt. The 7-pin tumbler key design is unique to the company and is not available commercially. In addition, the product measures 2 in. × 1¼ in. and is generally flat or face mounted with ¼-in. mounting bolts through the front of the housing. The reduced footprint is approximately 50% smaller and nearly 60% lighter than the company’s Standard Duty Series Type F model.
Kirk Key
