Ecmweb 5987 Pat516lp8us Wcolors
Flash pattern LED luminaires
Jan. 6, 2014
Wide-angle lens Operate as single unit or synchronized with up to four units Rated for indoor and outdoor use
LP8US surface-mounted LED luminaires feature a wide-angle output lens cover that is available in blue, red, yellow, and clear. Designed to be operated as a single unit or synchronized with up to four units, the products can be quickly programmed from a selection of 33 different simultaneous or alternating flash patterns covering a range of flashes/minute variations. Rated for indoor and outdoor use, the sealed design provides operation in temperatures ranging from -40° to 65°C (-40° to 149°F). Measuring 4.79 in. × 2.66 in. with a recessed depth of 1.31 in., the CA Title 13 compliant and SAE J595 certified luminaires are rated for 10VDC to 30VDC operation, with 1.1A (max) current draw.
Patlite
For more information, visit www.patlite.com.
