Ecmweb 7582 Appleton Dsin Use 1
Double snap connectors
July 16, 2015
Install without the need for tools or a locknut Straight, Straight for Old Work, Duplex, and 90 Degree models Reusable
Speedlock double snap connectors allow users to connect armored cable, metal clad cable or flexible metallic conduit to steel boxes and enclosures twice as fast as traditional connectors without the need for tools or a locknut, according to the company. Available in several configurations, including Straight, Straight for Old Work, Duplex for installing two cables in a single KO, and 90 Degree, the cULus-listed zinc products install in seconds. Simply snap the connector onto the cable, and then snap it into the knock-out. In addition, they are reusable and designed to terminate 3/8-in. or ½-in. flexible conduit in ½-in. steel box KO's or enclosures in dry locations. Red insulated throats create a smooth pulling surface to protect the wire insulation from damage.
Appleton
