The Flip Joint cable cutter is a 3-in-1 tool that allows users to cut with the cable cutter, slice with the sheath knife, and strip vinyl-coated wires with the wire stripper. The 8-in. tool allows sharp, clean cuts through vinyl-coated cable or bare, multi-stranded copper or aluminum wire up to size 10/3. Designed with industrial-grade plastic dipped grips, the smart contour handles provide comfort while cutting and slip resistance while slicing.
Wiss
For more information, visit www.wisstool.com.
