Air-to-air heat exchangers
Now offered in 120VAC and 24VDC models, the Stratus line of air-to-air heat exchangers features compact, deep, and tall frame sizes.
Nov. 15, 2013
The Stratus line of air-to-air heat exchangers now includes 120VAC and 24VDC models. The product is a closed-loop cooling system that employs the heat pipe principle to exchange heat from an electrical enclosure to the outside. Each heat pipe has an evaporator section and a condenser section that are separated by a permanent baffle to provide a closed loop. The coil systems use aluminum end plates and baffles, which the company says improve conduction and reduce corrosion. Available in models for use with NEMA 4 and 4X enclosures, the exchangers are offered in compact, deep, and tall frame sizes with up to 72W capacity, and feature two circulating fans with sealed overload protectors.
AutomationDirect
For more information, visit www.automationdirect.com.
